Reusing the stock crank??
Old Apr 8, 2008 | 05:03 PM
pjsevo8's Avatar
I am currently building a new motor. I took the block and everything down to the machine shop and it seems the crank needs to have 10 thousands taken off of it. I have heard that the DSMers have not had great luck with taking that off the crank. Is it ok to have this taken off the crank for a rebuild and will it stay strong that way? My car should be pushing around 700whp on a mustang this time around. The build will have wiseco pistons and groden aluminum rods. Any input would be great as I need to find out the answer soon.
thanks
PJ
Old Apr 8, 2008 | 05:07 PM
PureDsm's Avatar
i would say get it done and then go and get it balanced with the pistons, and rodsn and rod pins? good luck..
oh yea you could do a 4g64 crank instead
Old Apr 8, 2008 | 05:09 PM
WHTEVO's Avatar
The better way would be to just re-size the rod ends. Good luck.
Old Apr 8, 2008 | 05:43 PM
CandCPerformanc's Avatar
How exactly does sesizing the Rod ends help the fact that the crank needs to be cut to the next size down to be cleaned up from any minor scoring?
Go ahead and have the crank cut to .010 under you will have no issues with it unless you had planned on running it in say 750-800+ engine and having it reballanced is not a bat idea should only cost roughly 100-150 to get it back to 0 ballance.
Old Apr 8, 2008 | 06:09 PM
pjsevo8's Avatar
not sure but the numbers could be somewhere around there. I just dont want to end up doing it again. Anyone running high horsepower on a cut crank? I would like to know because I might be shooting for that power someday.
Old Apr 8, 2008 | 06:42 PM
pjsevo8's Avatar
any more input?
Old Apr 9, 2008 | 04:49 PM
pjsevo8's Avatar
no more input on this?
Old Apr 9, 2008 | 05:43 PM
CO_VR4's Avatar
The answers you are getting make different assumptions, because your original post was not complete. The crank could be damaged on the main journals, or on the rod journals, or both. The person that responded to resize the rod big end did not consider that the crank journal was probably damaged, which required it to be recut smaller...
Many people would say that you should always look for a crank that can remain standard/standard sizes on the rod and main journals. With spare 2.0L cranks available for $250 or less, it's not a place to cut corners on a higher than stock HP build. Even if you buy a new factory or Eagle standard stroke crank, it's the critical part of your build. Better safe than sorry.
Evolution7GSR
Oct 15, 2016 09:06 PM
ryanholder24
Aug 29, 2016 07:08 PM
ba109296
Mar 29, 2016 06:02 AM
Night12000
Sep 28, 2015 08:03 AM
3240
100
Sep 10, 2004 07:06 PM
