which piston for 2.4 ??
Old Apr 11, 2008 | 12:48 PM
nubi4life's Avatar
i bought an engine from R N R racing a while back and it was a 2.4 liter with wiseco pistons bored .20 over and honed. Cylinder # 4 piston rings went bad and i need new piston rings. my mechanic said that i might need a new piston for #4 too. is it possible that i could get just 1 piston from a site or do i have to buy all 4?? also which size piston do i need too??dont forget im a newbie guys please help me
Old Apr 11, 2008 | 01:31 PM
RoadSpike's Avatar
You can order it from the wiseco catalog far as i know.
http://www.wiseco.com/Catalogs/Sport...Mitsubishi.pdf
You better be sure that part number is the RIGHT one.
Old Apr 11, 2008 | 01:39 PM
EVO8emUp's Avatar
It should just be a piston for a .020 over 4g64. Just make sure you get the same comp. ratio piston.
Old Apr 11, 2008 | 02:48 PM
jmartinez1170's Avatar
Hey man your best bet is to take it to someone who builds engines and have them replace all 4 pistons and bearings. Lets just hope your walls are not notched up or anything if so you will need a new block.
If thats the case you can get a used 4G64 block at any junk yard for dirt cheap clean & bore it out and rebuild it.
Old Apr 12, 2008 | 07:26 AM
nubi4life's Avatar
i cant believe this is happening to me guys. ive got the worse luck with cars. lol. thanx for helping me out. so i shouldnt just replace 1, replace all 4. my mechanic said the walls are good. maybe just bad rings?? what do you think
benIX
Dec 25, 2016 10:35 AM
LacouK600
Sep 5, 2013 11:41 PM
konstantinosIX
20
Oct 26, 2008 06:09 PM
bishiboy
Nov 26, 2004 11:53 AM
