Anyone running HTA 35R in a .82 "5 bolt" housing?
Old Apr 11, 2008 | 11:44 PM
omniprobe's Avatar
I've read through lots of threads and seen mostly .63 and some .82 but not in the 5 bolt housing. Anyone? dyno charts?
Old Apr 12, 2008 | 12:05 AM
riceball777's Avatar
why would you want to run a 5 bolt housing. only ams used the 5 bolt housing because they feed the waste gate through the turbine housing. 5 bolt housings are known to make a little less power and they all have a 2.5 inch outlet
this is what u want to run if you can
HTAgt35r with a t3 open scroll .82 ar with a 3 inch v band discharge. if you dont have clearance run the standard t31 housing
Old Apr 12, 2008 | 12:07 AM
omniprobe's Avatar
Wouldn't you need a v band o2 housing? In this form the outlet is 3 in correct?
Old Apr 12, 2008 | 04:12 AM
yes you are correct
Old Apr 12, 2008 | 05:31 AM
Evo8Emperor's Avatar
Nah you wanna run a twin scroll 35r 1.06 ar i believe. If your gonna spend the money go TS.
wshihdnevo
12
Sep 21, 2011 09:11 PM
Johnboy1065
10
Sep 28, 2008 06:45 PM
Johnboy1065
152
Sep 25, 2008 03:32 PM
Noogles
Oct 18, 2006 11:31 AM
