difference in evo 8 and 9 throttle body?
Old Apr 14, 2008 | 03:31 PM
gsXingU's Avatar
hey guys, i was just wondering if there was a difference between the evo 8 and 9 throttle body?
Old Apr 14, 2008 | 03:54 PM
scheides's Avatar
EvoM Moderator
They are identical, I believe. I swapped mine out with a ported IX one and noticed no differences.
Old Apr 14, 2008 | 06:05 PM
lwpz's Avatar
Did you port the intake manifold as well? Combine they are worth 7-8whp. Just the throttle, there would probably little or no gains
Old Apr 14, 2008 | 07:42 PM
gsXingU's Avatar
ok so they are identical. For some reason i was under the impression the 9 has some other different sensor.
Old Apr 14, 2008 | 11:25 PM
Aby@MIL.SPEC's Avatar
03/04 tb's have a heat actuated idle air bleed flapper device. the 05/06 tb's do not have this.
you can install either tb onto either year evo, it will fit & work fine, however there is a slight difference.
i will post pictures tomorrow illustrating the differences.
Old Apr 15, 2008 | 07:05 AM
scheides's Avatar
EvoM Moderator
Thanks captain obvious, way to go OT and yes I did both. Should be worth more power than that though.
Good to know! Any way to tell from the outside? Please post pics!
Old Apr 15, 2008 | 07:24 AM
yes.
Old Apr 15, 2008 | 03:26 PM
gsXingU's Avatar
ok so i guess i should say the reason why im asking is because i want to buy a stock tb for my evo 9 to be ported from buschur (you know the $300 tb port job). But the only one i can find for sale is from an evo 8. Am i gonna be ok?
Old Apr 15, 2008 | 03:31 PM
gsXingU's Avatar
oh man i just read it again. It is done on an exhange policy. I guess they dont use the same tb i send them. They just wait for mine to come in and then they ship the one already made. hmmmm
Old Apr 15, 2008 | 04:49 PM
Exciting News's Avatar
No offense, but the guy answering your questions performs the service you're looking for too. Maybe try that route.
Old Apr 15, 2008 | 08:33 PM
gsXingU's Avatar
well then talk to me buddy...lol - no offense taken
Old Apr 15, 2008 | 10:21 PM
lv05evo's Avatar
+1 on what he said. MIL.Spec also doesn't charge $300, they cost less.
Old Apr 16, 2008 | 11:15 AM
PM'd
Old Mar 5, 2013 | 07:57 AM
evoVI_PR's Avatar
Sorry for reviving an old thread.
Is there any way to eliminate this temperature controlled idle flapper?
Thanks,
Old Mar 5, 2013 | 09:36 AM
yeah, un due the screw, pull out the device, use plieers to physically pull out the mechanism & now your left with a aluminum piece that holds the o-ring. re-assemble.
