Stolen thoughts from Simon Norris on T04Z
Old Apr 21, 2008 | 04:35 PM
JC evo1's Avatar
Originally Posted by crcain
Well two things... I think engine dynos can be loaded however you want. So you'd have to suspect Norris would set it up so it was similar to the load you'd see on the road. Norris isn't trying to sell anything here... like many vendors... he is just answering questions about his own build.
Secondly, he says it spools better than a GT35R... regardless of how the dyno loads the engine, it's interesting to see someone say they've essentially found a GT35R killer.
I agree with the essence of your comments Whoop_Ass... just pointing out that I think the results here are more true than the false.
how can a turbo thats physically larger in every way spool faster than a 35r, both with an open single volute? Im not buying it
Old Apr 21, 2008 | 04:58 PM
Boltz.'s Avatar
FCOTM Winner
^ more aerodynamic, better efficiency
Old Apr 21, 2008 | 07:55 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I'm not sure why you wouldn't "buy it". Just like everything else, turbo technology improves. The 35r is not the end of turbo development.
Old Apr 21, 2008 | 08:16 PM
JC evo1's Avatar
T04z is hardly new turbo technology
Old Apr 21, 2008 | 09:26 PM
03whitegsr's Avatar
1997 I think is when that T67 (err T04Z) came out...
Old Apr 22, 2008 | 04:46 AM
chuntington101's Avatar
Originally Posted by DTM
Well we have tested a few versions of the T04Z wheel, maybe not in Norris' configuration but none the less similar found here:
https://www.evolutionm.net/forums/sh...&highlight=dtm
And
The basis was something large than a 37R and smaller than a 42R with a 94mm exducer.
The results were great. The T04Z is a great turbo if setup properly with the right head work and bottom end rpm capacity.
Now The standard 35R is a great turbo, BUT there are many good options out there now.
cant wait to see more info on your kits! its nice to see poeple thinking ourside the box and trying new things. people get Very set in their ways.
and to others that are questioning the T04Z in comparision to the GT35R, who cares?? if someone like DTM can supply you with a turbo kit that will out spool and give more power then what dose it matter what turbo they are using?? lol
Chris.
Old Apr 22, 2008 | 05:47 AM
Flyin EVO 2's Avatar
A friend of mine was running the T04Z in a 2g DSM. It's very similar to the power output of a T67/37R. Spool time was also similar to a T67/37R.
Old Apr 22, 2008 | 06:06 AM
JC evo1's Avatar
thats cause its pretty much the same turbo.
Old Apr 22, 2008 | 06:08 AM
slicedbreadno2's Avatar
This looks very promising.
Old Apr 22, 2008 | 07:43 AM
Mr. Evo IX's Avatar
Again on an engine dyno the numbers mean as much as they do on a DLL style calculation. just don't get hung up with a numerical value that means didley.
Right, just like ALL Dyno numbers. Dyno numbers only compare directly with other numbers made on the same Dyno. Incidentally DLL numbers compare great with DLL numbers.
Old Apr 22, 2008 | 07:52 AM
mike 99gsx's Avatar
This is correct but just remember that when I put a T04Z on my 2g back in 2004, it was the only choice in regards to a BB CHRA T67/P trim. The variants from the other turbo companies in the US started coming out around 2006.
The HKS T04Z also used a T4 divided housing (unlike most of the current variants who use the T3). Again nothing that you can't get made here now in the US but it was unique at the time.
Old May 5, 2008 | 04:07 PM
crcain's Avatar
And sadly this is what happened to the car today
Thead here: http://www.lancerregister.com/showthread.php?t=202709
Old May 6, 2008 | 02:45 PM
crcain's Avatar
Vid of this car and turbo in action.
Best of Evo vid I've ever seen and a crash in the end to boot!
http://www.lancerregister.com/showpo...&postcount=187
evo4.5
Sep 29, 2011 09:06 AM
crcain
18
May 11, 2009 12:27 PM
jp@shearerfab
Jun 12, 2007 05:49 AM
GalantT3
Oct 11, 2005 08:50 AM
Tachyonzero
Sep 23, 2005 11:13 AM
