Dual springs = smoke under load :(
Old Apr 18, 2008 | 08:11 PM
evl08's Avatar
Hey all.
I have dual springs, ti retainers, and seats from supertech. The vendor I got them from on evom said that was all i needed and i'm guessing the shop that put them in didn't notice there was no clearance with the OEM seals. I have smoke under load and need these I think...
Supertech Valve Seal: VS-H6.6I x 8
Supertech Valve Seal: VS-H6.6E x 8
Is anything else required to be replaced that may be damaged such as new springs, or anything else?
Cheers.
Old Apr 18, 2008 | 08:18 PM
Boost3dxEvO's Avatar
Originally Posted by evl08
Hey all.
Cheers.
Hey. These are the correct seals that you need for the supertech duals.. How many miles on the duals with the OEM seals? I put the OEM seals in when I did my supertech duals and haven't had a problem yet.. but I bought the right supertech seals just in case.. And what color is the smoke? and is it out of the exhaust or motor? I am guessing its blueish, white smoke out of the exhaust?
Old Apr 18, 2008 | 08:22 PM
AWD Motorsports's Avatar
yes thats what you need.. They should have been installed when they did the springs.. we just did 2 cars with supertechs and NO smoke issues..
Old Apr 19, 2008 | 07:32 PM
evl08's Avatar
It's a blueish coloured smoke out of the exhaust. They've been in for about 10k km. When they were first put in I noticed on start ups that there was a little bit of smoke as well, but that seemed to stop pretty quickly.
It's annoying to have the head pulled off again just to have these put in! I may as well add some head studs and give the head a bit of a clean up while it's being done.
My only concern would be if any other parts need to be replaced because they have been damaged from rubbing against the seal?
Old Apr 19, 2008 | 07:55 PM
The head does not need to be pulled off to do the seals.. It can be done in a few hours on the car
BlackEvo_5
May 28, 2013 07:01 AM
elhalisf
May 26, 2013 10:28 PM
Craig King
26
Oct 31, 2012 05:42 AM
EGbeater
14
Apr 15, 2010 05:31 PM
Boost3dxEvO
48
Aug 16, 2008 07:57 PM
