lower front strut bar
how important is this? since I installed my DC Sport dp with cat delete I cannot reuse and if I try to use spacers the bar is too low to the ground, btw car has Tein S-Tech's installed.
lower front strut bard
how important is this I had to remove due to the DC Sport downpipe I installed with cat delete the bar could no long fit, when I use spacers the bar is droping to low any ideas?
It helps to tie the chassis up a little. I'm using an RMR replacement brace that takes the place of both of those bars and clears my 3" downpipe:
http://www.lancershop.com/customer/p...cat=103&page=1
From: in a place I dont want to be BUT here so you and I can be free!
From what I gather, if you do drag racing, you DO NOT need to keep this item. But, for road courses and autox, those type of cornering activities that do push the car to its limits, it would be a good thing to keep.
I am pretty sure I will be pulling mine off of the car this weekend, and leaving it off for now.
--mark
--mark
thats what i did. I used the helix 3 inch dp and just threw on some washers and i had some great clearance. I'm on swift/billstein set up for my evo 8 gsr.
I just ran over to my local hardware store and bought 10 washers total. 2x for each bolt and that was more than enough clearance.
I may look into an aftermarket replacement unit.
michael2014
Feb 2, 2016 04:40 PM
psychlancer
04-06 Lancer Ralliart How To Requests / Questions / Tips
Sep 14, 2005 03:07 PM
