EVO 4 transfer case (Centre diff)
Old Apr 22, 2008 | 03:52 AM
PIGG1E's Avatar
I used the search but couldn't find wat i wanted
My E4 has a bit of a problem with the front diff . turning right the car is making serious clunking noise and feels as though the engine is gonna get thrown outta the car . when i jacked the car up and went to turn the left front wheel forwards it goes about 1/ 8of a turn and locks up . turn the right front wheel and it is sweet . but if you turn the left wheel backwards it is making a knocking sound.
Had a friend who knows not much about evo's say it might be the centre front diff .. and that there normally located in the bottom of the gearbox and that the gearbox may have to come out and be stripped down and diff replaced then all put back together .. when he told me this i said maybe it is the transfer box as i know they are a common fault .. but he was pretty convinced that the sound was coming from the centre front diff (he is a lot more mechanically minded than me so i can only go on what he has said) . So he said if we drain the gearbox oil and find some chunky's in there then we will know for sure that it is the front centre diff (he said he thinks it may be the spider gears as it is only doing it while turning right)
Anyhow have been looking for 2nd hand E6 gearboxes and then was informed that the centre front diff is not located in the bottom of the gearbox but is also in the transfer case !!! Is this correct and if it is correct does that mean that the gearbox will not have to come out to replace the transfer box ??
I will not be working on the vehicle but i like to know how everything works and what is needed for the repair . so if anyone out there has some kinda idea on maybe what it is and what would be involved to repair then any info would be great thanks
Old Apr 22, 2008 | 06:04 AM
crcain's Avatar
The center diff exists in both the gearbox and the transfer case
There is an open diff in the gearbox and then a viscous coupling unit in the transfer case. Chances are your problem is the front diff which also exists in the transfer case.
Drain the oil of both your gearbox and transfer case and look at the oil and drain plug for debris. The transfer case contains the front diff, VCU, and ring and pinion to the driveshaft.
Old Apr 22, 2008 | 08:57 AM
94AWDcoupe's Avatar
The center diff is huge compared to the front diff. The front diff will break 100 times before the center diff breaks once. Your problem is going to be in the t-case. The front diff is broken.
Old Apr 27, 2008 | 02:50 AM
PIGG1E's Avatar
So does the gearbox have to come out to fix this or does it just have to have the transfer case taken off ??
Old Apr 28, 2008 | 12:59 AM
94AWDcoupe's Avatar
just t-case.
Old Mar 23, 2018 | 04:16 PM
TonyK94's Avatar
Sorry to bring this up after so long ! 😅
Got a violent clunk when driving changed top mounts bottom arms n driveshafts took tc box off today havent split the box as im thinking it could be centre diff(in gearbox???) not front diff
unsure if my car has centre and front same as evo 4 as it has a evo8lump and running gear etc 380hp so im thinking ive been launching too much
Old Mar 23, 2018 | 07:10 PM
barneyb's Avatar
I'd look at the front diff in the transfer first. Stock, it came with slintered gears.
Old Mar 23, 2018 | 11:16 PM
TonyK94's Avatar
by slinted gears do you mean that the inside of the transfer box the diff has worm gears or the non worm looking one ?
Old Mar 23, 2018 | 11:18 PM
TonyK94's Avatar
Also when i split the box other than diff bolts anything else that could effect it as its all spinning properly at the moment with case intact both the driveshaft and the gearbox bolt in side spin when the other does too?
but the bottom where prop goes into doesnt spin properly by hand? Is it meanto ?
Old Mar 23, 2018 | 11:37 PM
barneyb's Avatar
I don't know what you have but the USDM Evo 8 has an open front differential - pure standard construction. I own an USDM Evo 8 but I've never had the transfer case apart but I've read on here that the reason it tends to fail is because the side gears are slintered metal. Slintered metal is ground up steel and I don't know what else, put in a mold and heated in a furnace until it fuses together. Its a cheap way to make a gear but not as strong.
With differentials, put motion in and motion has to come out somewhere else. So, turning one wheel and having the other turn is normal.
Old Mar 24, 2018 | 02:24 AM
Bladey's Avatar
watch this. It will explain what is going on, very common on evo 4-6's recommend replacing the tcase and while you're at it upgrade it with the bolts
Old Mar 24, 2018 | 02:56 AM
TonyK94's Avatar
Originally Posted by Bladey
https://www.youtube.com/watch?v=o9gOdjzg0SI watch this. It will explain what is going on, very common on evo 4-6's recommend replacing the tcase and while you're at it upgrade it with the bolts
Literally just went to c1r ralliart and got some bolts going to take the box apart and see whats what, if its not bolts what shall i check next?
brt426
12
Nov 12, 2011 07:55 AM
nocabiwiksmx
13
May 27, 2009 09:01 PM
Mr Whippy
Apr 6, 2009 10:48 AM
evo3barboost
Sep 14, 2006 11:28 PM
troe666
10
Sep 5, 2006 01:01 AM
