Look what i did to my front diff
Old May 26, 2009 | 10:57 PM
nocabiwiksmx's Avatar
Launching it down a drag strip, lunched the front diff halfway through 1st gear lol
Didnt get much change from NZ$5k lol
This is sorta what the diff looks like when in 1 piece
This is it in pieces
Its definately a helical front diff, note the worm gears
The rest of the insides of the transfer case
The transfer casing. Evo gearbox on right and primera box on left
Old May 26, 2009 | 10:59 PM
justa4banger's Avatar
danggg....how much whp on your car?
Old May 26, 2009 | 11:13 PM
heel2toe's Avatar
Looks like someone launched without preloading the drivetrain...please tell me your car is making some serious power
Old May 27, 2009 | 01:12 AM
prolly around 320whp
its an evo 7 gsr with TBE (80mm kakimoto... LOUD), 21psi and tune. nothing too fancy
1st run i got 13.5 at 175kph woohoo
2nd run it let go
was using 5000rpm launch control and tephra NLTS (which rocks btw)
what do you mean when you say 'preloading the drivetrain'?
Old May 27, 2009 | 02:22 AM
Toxin's Avatar
He means slowly slipping the clutch till the car starts moving so all the drivetrain parts are already positioned "next to each other" in the direction where you're going.
For example a very stupid mistake you can make is going past the stage lights and then going reverse just to the point where you get ready to launch it. All your drivetrain is leaning on the parts in the opposite direction of where you'll be going and when you launch there's still gaps there and that's one of the ways of breaking stuff really fast.
Hope this made some sense.
Old May 27, 2009 | 11:06 AM
mmmmbst's Avatar
Veteran: Air Force
It sucks that it broke but i think its sweet when parts really break instead of something small where you have to replace it. That thing was destroyed.
Old May 27, 2009 | 11:20 AM
Slip the clutch dude....
Old May 27, 2009 | 11:38 AM
jve153's Avatar
ouch, thanks for the pics tho. looks like its time to talk to shep
Old May 27, 2009 | 11:47 AM
SaTa's Avatar
t4 primera ftw (hopefully with a tiny t25 snail in front)
Old May 27, 2009 | 12:16 PM
dtuned's Avatar
Looks like someone didn't have proper torques set in their TC, and not preloading was just the ticket to make it all explode. 320WHP shouldn't have killed it had it been set up properly.
Old May 27, 2009 | 01:22 PM
CWhiteRun's Avatar
Could've been a lot worse...had a buddy wreck his car over something like this but his ring and pinion let go too.
Old May 27, 2009 | 03:33 PM
riceball777's Avatar
Wow. I have not seen anyone do that to the stock front LSD.
Most of the time people break the stock front. 03-03 ego front open diff but now the LSD
Old May 27, 2009 | 08:12 PM
my expensive mistake then haha though wouldnt the clutch restrictor pill slip the clutch a bit anyway?
coming from FWD's i used to just dump the clutch and modulate the throttle
another theory is that whoever changed the bolts on the helical lsd to cap screws overtightened them because there appears to be mini cracks around them.
oh well if you're gonna break something, do it right and totally f*** it haha
funny you should mention, a friend of mine has a p11 t4 with sr20vet (xtrail engine). quick car
Old May 27, 2009 | 09:01 PM
Evoryder's Avatar
more slip, vs the dump. Dump sends drivetrain shock, shock = breakage. Not the end of the world, ralliart lsd or quaiffe lsd and you'll be back in no time.
Note: removing the factory restrictor pill allows for easier clutch slipping.
2DCVIN
Jul 3, 2018 10:39 PM
2DCVIN
26
Apr 13, 2018 06:18 AM
2DCVIN
39
Mar 19, 2017 04:49 PM
2DCVIN
Apr 4, 2016 09:38 PM
MYRAGE
34
Jun 22, 2007 08:35 AM
