Ix Rs Finale:) 410whp/437tq
Old Apr 24, 2008 | 12:30 PM
  #46
TTP Engineering's Avatar
The clutch line to the slave cylinder broke on the way back from USP, not sure if he got it fixed yet.
Old Apr 24, 2008 | 01:42 PM
  #47
RyuEvoIX's Avatar
That sucks! I want to see a 10second pass posted.
Old Apr 24, 2008 | 02:41 PM
  #48
Most-Wanted's Avatar
I wish I had better news...
OK guys, here is the scoop. I have been plagued with ridiculous issues. First the clutch line split on the way home. I fixed the stock line in case the replacement didn't show, but AMS sent me a nice braided line overnight. I installed the line and the car felt fine. We loaded it up and headed to the track. First burn out felt awesome and as soon as I left the line the clutch slipped the whole pass. It was wonderful to spend thousands of dollars to run a 12.0@114 again. I have no idea why this clutch failed. My last evo went consistent 1.5 60's/ 11.50's on the Exedy Twin and that evo was full weight. I will recommend for everyone to buy the lower braided clutch line($26) from AMS as a precaution. My line failed and it is probably what caused this string of events. I'm at a point where I just don't know what I want to do. I may just send the car to Buschur's for a complete engine/head build and HTA 35R. This car has 40k miles on it and I just keep picking away at things and there always seems there is something else to fix or change. I would just like to go the track and have some fun for once. Sorry guys, but I seem to be at a stand still for the time being. I have to make a decision whether to just fix the current issue or just go big and finish the car completely the way I want it to be eventually anyways.
Old Apr 24, 2008 | 02:52 PM
  #49
boostGotMeLaid's Avatar
nice.......sorry about the issues trust me i know how u feel....
Old Apr 24, 2008 | 02:54 PM
  #50
oh quick ? what belt did u use to swap without Ac n still keep the steering????
Old Apr 24, 2008 | 02:57 PM
  #51
Thanks, factory Mits belt. Double check with Mike at AWD.
Old Apr 24, 2008 | 02:58 PM
  #52
AWD Motorsports's Avatar
I would put a clutch in it and go back after the 10's 1st.. to go from 11.2 to 10.99 isnt going to take much.. if a slipping clutch has deterred you then you have no idea what your getting into to run 9's.. keep that in mind.. let me know what you decide..
Old Apr 24, 2008 | 02:59 PM
  #53
evolved83's Avatar
I would try to attain your goal of hitting 10's on stock turbo first, as you are very close. Then send it off to buschurs
  #54
its an RS belt w/o AC from mitsu.. A/c is an option on many RS models so they have a belt for no AC ready to go..
Old Apr 24, 2008 | 03:04 PM
  #55
Yeah I know, its just the down time is killing me. I think I am just going to go with the Tilton Twin Carbon for now and blow out a 10 sec pass to make evryone happy. Cwill can install it when he gets back. Then I will talk with DB for a full build.
Old Apr 24, 2008 | 03:12 PM
  #56
thats my point, the downtime to get a clutch back in the car compared to rebuilding the motor, AEM , fuel system, turbo kit , is going to be a big difference..
Old Apr 24, 2008 | 04:55 PM
  #57
vwjeff's Avatar
WOW Brian I am sorry to hear about the clutch slipping man
Good luck getting her back up and running!!!
Old Apr 24, 2008 | 05:14 PM
  #58
Sky Evo X's Avatar
Can't go wrong with TTP. Great looking car!
Old Apr 24, 2008 | 05:21 PM
  #59
Sky Evo X's Avatar
I think you have nothing to prove. Your mid 11s like 2 years ago proves that. If your goal is to go big, I think you should just do it now, and save some money =]
Get everything done the way you want, and be proud of your completed project.
But then again, going for 10s on stock turbo is also very cool in its own right,
even though you know you could easily run it, its not the same as doing it.
Is the clutch the only thing in the way now? If so, why not just upgrade it to handle the power of your ultimate goal, and run your 10s, then upgrade the rest of the car?
Old Apr 24, 2008 | 05:32 PM
  #60
9sec9's Avatar
Brian, as you know, been there, done that. The main goal is to make yourself happy. Do what YOU want to do. If you truly want to see 10's on the stock turbo, fix the clutch, run the 10's, then go big. You'll never regret reaching a personal goal. You will regret never reaching a personal goal. Most of all, do what's in your heart for yourself. Everyone else will support you regardless. Just remember you signin name.
Good luck with WHATEVER you do. Afterall, it's your goal, not ours.
