Start up precautions after long down time?
Old Apr 24, 2008 | 10:31 PM
cal1mr's Avatar
The IX has been sitting for almost 4 mo now and I'm wondering if there is anything to consider before starting her up. I know there couldn't be much to actually do about it but wanted to ask here just in case I'm overlooking some concern.
Old Apr 24, 2008 | 10:33 PM
Maddy88's Avatar
nothing i really wouldnt think of just let it idle for a bit i'd say it should be fine
Old Apr 24, 2008 | 10:39 PM
cal1mr's Avatar
Yeah, I figured as much. Had to ask though
Old Apr 24, 2008 | 10:40 PM
evovin's Avatar
I would change the oil if its me before I start it. Esp if the oil you left there for 4 months was used over 2k miles.
Old Apr 24, 2008 | 10:48 PM
dude's Avatar
If you really wanted to be **** you could pull the spark plugs, pour a teaspoon or so of oil in each cylinder, unplug your fuel pump and crank the engine several rotations using the battery to slowly lubricate the pistons/rings/cylinder walls and get the oil pumping a little. This approach is much more gentle than starting the car and having it go to fast idle (~2000rpm) instantly.
Then reconnect your fuel pump, reinstall plugs and fire her up. Any remaining oil will burn off almost instantly and you'll be good to go.
A lot depends on where the car was stored and what the humidity and temperature levels were...YMMV
Old Apr 25, 2008 | 10:57 AM
cal1mr's Avatar
It's been in my garage with temps staying pretty constant (60-80°) although with a period of high humidity durring the rain this winter.
Old Apr 25, 2008 | 11:54 AM
Burklow's Avatar
+1 On oil change. Never hurts.
Old Apr 25, 2008 | 12:06 PM
codean's Avatar
Watch your oil pressure light when you do end up starting it. Make sure it turns off a few seconds after start up. Dry evo oil pumps have a very hard time geting primed.
Old Apr 25, 2008 | 12:20 PM
GroundHog's Avatar
^^^ that's good to know
AustinTorset
Oct 20, 2015 01:35 PM
Laddious
Dec 8, 2009 11:55 AM
griffeyr
Feb 8, 2009 06:14 PM
4drboost
AEM EMS
Oct 29, 2008 02:09 PM
drucea
Jun 5, 2005 05:42 AM
