Fixed my Lockout problem with my ACT HDSS
Old Apr 27, 2008 | 01:09 AM
Turbo Kyle's Avatar
I had some problems with what people would call "Lock out" this is when your car wont go into gear. This typically happens in a high RPM situation...over 7000 RPMS. I had my clutch pedal adjusted out pretty high. I didnt want to adjust it out too far in fear of "Preloading" the pressure plate, witch would cause the clutch to not fully engage possibly causing slip under WOT. However, I was having some "Lock out" when I would get over 7000 RPMS on the 1-2 shift. It is pointless to go over 7K on the stock turbo and cams, but sometimes crap happens. The only time I go over 7K on purpose is in 4th gear ragging it out for a 1/4 mile pass instead of going onto 5th. Anyway, I decided to adjust out the clutch pedal a little further (higher) and see what happens. I went for a ride and could tell right off the bat the car was shifting easier (the car was cold). After a few miles when I got everything warmed up I went for a rip....took the car to 7800 in first and it shifted like butter right into second....took it to 7600 in second and 7600 in 3rd...the darn thing shifts so freaking good I could not believe it. I am 100% more happy with this car now…time to go racing! I had missed 2nd a few times…due to my clutch being adjusted incorrectly. I have been driving/racing stick cars for over 10 years….Im a pretty good driver….and this was annoying the heck out of me…Im satisfied now! I love the ACT HDSS with my Xact Prolite Flywheel. So if your having problems give your clutch pedal a good adjustment.
Old Apr 27, 2008 | 01:37 AM
Turbo Kyle's Avatar
Oh yea, It launches nice too
Old Apr 27, 2008 | 01:41 AM
dsmfan95's Avatar
I never had any issues with my ACT HDSS locking out until recently, but I believe that is primarily due to the EvoGreen making too much power for it. Good post!
Old Apr 27, 2008 | 02:09 AM
Turbo Kyle's Avatar
Thanks man, try pusing out the rod a little further....it might help. As the clutch wears you need to adjust the peadal out to compensate.
Old Apr 27, 2008 | 07:19 AM
dsmfan95's Avatar
I'm just going to go ahead and change it out. I've already got the parts to do a new clutch and swap out some things in the tranny
Old Apr 27, 2008 | 07:45 AM
Liqquid's Avatar
+1 on this, takes a few tries to get it dialed in just right, but worth the effort!
Old Apr 27, 2008 | 10:33 AM
RevMoto's Avatar
Are you serious? Adding more power will not give you lock out. Especially not from a green.
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
High_PSI
141
Jun 15, 2014 05:10 PM
scheides
Mar 1, 2014 09:45 AM
deeman101
60
Jul 18, 2013 01:29 PM
tehSteve
Jul 5, 2011 08:51 PM
