560cc injectos
Old Apr 26, 2008 | 09:32 AM
W2J's Avatar
W2J
560cc injectos
just trying to confirm would this support 27psi on evo 8 motor with turboback and walbro using the evo9 10.5 turbo if not how much boost max can I run
Old Apr 26, 2008 | 02:37 PM
PineApple's Avatar
Isn't that just about the stock injector size? My stock injectors were maxed at 21psi with the basic bolt on mods on my IX.
Old Apr 26, 2008 | 02:49 PM
moey124's Avatar
yeah it is 560 cc... i never knew it can run up to 21psi..I thought it could run up to 22psi
Old Apr 26, 2008 | 03:09 PM
mcwop23's Avatar
then there was a mistake with the tune
Old Apr 26, 2008 | 03:13 PM
PineApple's Avatar
Two different tuners told me the same thing when I was getting tuned. Got larger injectors and problem solved.
Holy hell it is hot today.
Old Apr 27, 2008 | 11:44 AM
AWDBus's Avatar
The type/oct. of the fuel will make a difference with how much boost you can run on what injectors. Plus the experience of the tuner will make up for the rest.
Old Apr 27, 2008 | 01:51 PM
gsrboi80's Avatar
I run 24 psi all day in my cammed VIII not out of fuel here on the stockies
Old Apr 27, 2008 | 02:27 PM
PineApple's Avatar
When I got tuned for the 23psi and I am cammed also and right around 6400 is when I start going lean.
