downpipe boost spike
Old Apr 27, 2008 | 02:12 PM
vaflyboi757's Avatar
I have a 05 evo with intake,catback, and now downpipe. after the install it started to spike to 22 psi and hit boost cut. even after reflashing boost cut to 319 im still having the same problem. what do i do to fix this. thanx
Old Apr 28, 2008 | 05:50 AM
pm anyone
Old Apr 28, 2008 | 05:55 AM
TeStUdO's Avatar
You probably need to re-scale your MAF.
Old Apr 28, 2008 | 11:34 AM
how do you do that?
Old Apr 28, 2008 | 11:38 AM
TeStUdO's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=249388
Old Apr 28, 2008 | 11:45 AM
RazorLab's Avatar
What intake is it? It must be really throwing off your MAF readings to hit over 319 load with 22psi.
Old Apr 28, 2008 | 12:36 PM
06ravenmr's Avatar
trying doing a boost leak test. when i up'd the psi on mine after 21 to 22 psi i would have the same problem u had. i thought it was in need of a tune but when it was on the dyno for tuning the problem still occurred. come to find out one of the couplers on the intercooler piping was leaking. we replaced the coupler and no more problem.
Old Apr 28, 2008 | 07:36 PM
sparky's Avatar
Have you logged AFR's since doing the new mods?
Old Apr 29, 2008 | 12:57 PM
i have a wideband but its not installed yet. i jus have the intake cone and adapter from AMS. i tried the link that Testudo sent me about scaling MAF, but the pics of the values didnt come up. ima try the boost leak test but i dont knoe how that effects boost cut?
Old Apr 30, 2008 | 07:02 AM
06ravenmr's Avatar
i dont know how or even saying a leak is causing it im just saying i was having a similar problem as u and it turned out to be a boost leak. imo its worth the few minutes to check just to be sure.
Old May 2, 2008 | 01:01 PM
tried boost leak test and its fine. does anyone have the pics from the MAF scaling form. for some reason their gone
Tbtalon94
Sep 28, 2014 11:51 AM
Dre1189
Feb 28, 2010 07:30 AM
stryfetew
Jul 18, 2007 02:34 PM
EvoDan2004
12
Sep 17, 2006 01:23 PM
DRAG
Feb 27, 2006 06:19 AM
