Smoke on startup
Old May 2, 2008 | 10:57 AM
boostedwrx's Avatar
This one of the threads - https://www.evolutionm.net/forums/sh...d.php?t=328634
Old May 15, 2008 | 07:24 AM
GIsnickers's Avatar
any fix to this issue??
i have the same problem - mine is not an MR.
Old May 15, 2008 | 08:13 AM
Markley02's Avatar
Compression is great. I checked the resistance of the coils, wires, injectors. Tried the 13 and 15 roms. put in new plugs. Threw a butt load of injector cleaner in it. lol.
Nothing has helped. Knowing that there is a TSB is great, but the stealership is a last resort.
Old May 15, 2008 | 08:27 AM
GIsnickers's Avatar
a bad valve would show in a compression test right?
Old May 15, 2008 | 08:52 AM
Markley02's Avatar
valve = yes
valve seal = no
At least in my situation, a valve seal would not cause my codes. For the codes to be triggered the car has to be up to temp and my car has no smoking issues at all once the car has been running for 30 seconds or so. For the car to misfire due to a valve seal there would have to be a good amount of oil going past one of the intake valves. Enough oil that you would see smoke whenever the car is misfiring.
Old May 15, 2008 | 09:16 AM
IDRNKV8's Avatar
Valve seals sounds right, but then not. You'd have smoke on initial startup. And why the CEL??? Just for the h*ll of it, Swap your coil packs, reset your light, then put a few miles on it, and see if your misfire has moved to the other cylinder. If it hasnt, youve completely ruled out the coilpacks. Keep us posted
Old May 15, 2008 | 11:35 AM
Joshs EVO's Avatar
I have the same problem except mine lasts for a few minutes while I drive. I am thinking that oil is getting past the rings. I have rapped it out a few times till its hits the rev limiter which I know is not good. so that why I think the rings are betting bad.
After about 5 mins of driving it goes away. When I hammer on it, downshift sometimes I can see some smoke.
Old May 15, 2008 | 12:06 PM
Markley02's Avatar
The simple fact that it only smokes when I want it to via throttle input makes me want to rule out valve seals. If it were a leaky valve seal it would happen every time. If I let the car idle for the first 30 seconds or go onto the throttle slowly it will never smoke at all. After checking the coils as it says in the service manual I do not think they are the problem. Swapping them is very easy so I proobably will try that sometime anyway. I have thought about swapping the injector's, but I haven't had the time yet.
Do a leak-down test and it will tell you for sure.
Old May 15, 2008 | 08:24 PM
Joshs EVO's Avatar
Do a leak-down test and it will tell you for sure.[/QUOTE]
I will have to get that checked out. thanks
Old May 16, 2008 | 09:58 AM
IDRNKV8's Avatar
Coils is easiest, just to get it outa the way
Old May 27, 2008 | 04:22 AM
Markley02's Avatar
Swapped the coils and did a boost leak test. No leaks at all and I still have the misfire in the #1 cylinder. Any more ideas?
Old May 27, 2008 | 04:52 AM
1NastyMR's Avatar
Blue usually means burning oil which might be a valve seal. When I go full throttle, My buddy tells me he sees smoke idk?
Old May 27, 2008 | 04:11 PM
holler mcdollar's Avatar
injectors would be the next thing to try for sure.
Old May 28, 2008 | 05:17 AM
Markley02's Avatar
I did as the service manual said and checked the resistence on the injectors. (service manual says between 2-3 Ohms. Mine are all 2.6 or 2.7) Common sense says that only means that the little electromagnet is working and wont tell you if they are clogged. Could an injector clog at 15K miles though?
Old Jun 13, 2008 | 03:50 PM
Mr. Evo IX's Avatar
Markley02, I think that TSB is for the 88590015 rom for the IX.
