vacuum lines/effect on boost
Old Apr 29, 2008 | 04:19 PM
Liqquid's Avatar
Wasn't getting anything the last couple days in the other section, so I'll ask it here instead.... if anyone has any experiences with this I'd love to hear about it!
I have the Forge MBC, and the vacuum ports are quite a bit bigger than the stock hoses and therefore the ports on the turbo/wastegate...
I'm interested to find out if this is made this way on purpose for the pressure in those hoses... I did not know the extent of the effect the restriction or lack of has on spool and taper until I read up on the stock boost control and different "pill" sizes... I of course removed all that and ran larger hoses to a "t" with one port capped and the other going to the turbo, (the "T"'s are all that I could find at the store to step the size down of the hose) Does anyone know if running the larger vacuum hose to my boost controller rather than trying to stretch (resulted in ripped hose) the stock size lines over the ports on the Forge will hurt the response of the turbo?
__________________
Old May 19, 2008 | 06:14 AM
JakeTheVIII's Avatar
It should not change it much if at all. Vaccum hose is vaccum hose, right?
Old May 19, 2008 | 06:36 AM
vvhiteix's Avatar
im not positive about what your asking...does diff diameter hose effect boost and boost taper?
Old May 19, 2008 | 12:03 PM
wingless's Avatar
The inside diameter of the hose will not matter aside from being able to the hose on the nipple securely.
The "pills" or restrictors in the stock lines are replace by the MBC which becomes the tightest restriction in the whole system.
Old May 20, 2008 | 05:49 AM
bova80's Avatar
just make sure you buy vacuum hose that isn't going to collapse, other than that it should be ok
bluedemon199
Jun 11, 2017 11:01 PM
mike594x
Dec 11, 2015 06:29 AM
GinNBoost
Mar 26, 2010 09:53 PM
Aux.
40
Aug 23, 2008 07:22 AM
AutoEuphoria
Jun 21, 2006 09:24 PM
