How would you go about removing this bolt?
Old Apr 29, 2008 | 05:18 PM
4TUN8's Avatar
It's rounding the bolt trying to take it off because of the way it's situated. The other bolts I could get a closed end wrench on, but this one I have to use an open end because of the stud touching the manifold.
I'm thinking of trying to get a hacksaw in there, let me know what you think.
BTW Click the picture to see a larger version.
Old Apr 29, 2008 | 05:31 PM
BluEVOIX's Avatar
Doesnt seem like its that bad of a shape.
What kind of sockets are you using 6 point or 12 point?
Old Apr 29, 2008 | 05:33 PM
Aby@MIL.SPEC's Avatar
look for a 6 point "brake line" wrench @ kragen/sears/napa, etc.
this type of wrench has a slot cut in it to fir over a brakeline & is beefy not to flex.
good luck
Old Apr 29, 2008 | 05:40 PM
Wicked E's Avatar
Last resort is Mr Dremel...
-E
Old Apr 29, 2008 | 05:41 PM
Curt@MrLed's Avatar
Former Vendor
chisel
Old Apr 29, 2008 | 05:44 PM
whitey4d's Avatar
Use a 6point socket and if it doesnt go to the flange of the nut then tap it with a hammer. IF that does work then the last desperation is buy a set nut removers from Sears or a tool truck(Snap-On, Matco) These look like a socket but with "twisted vanes" to bite whats left of the nut. You may have to hammer these on aswell for best results. Ive never had one of them to fail me yet. They also work great on rusted parts too.
Old Apr 29, 2008 | 05:45 PM
KcEvil8's Avatar
vice grip plier
Old Apr 29, 2008 | 05:46 PM
whitey4d's Avatar
Originally Posted by KcEvil8
vice grip plier
They should also work if you can them on. I think thats a header flange isnt it?
Old Apr 29, 2008 | 05:47 PM
IEXCELR8's Avatar
Man that bolt is touching the mani. I would hack it off just after the bolt so you will have room to get the bolt off.Loosen the bolt before you do this in case you need to hack the bolt in half it will be loose. Good luck
Old Apr 29, 2008 | 05:57 PM
spak920's Avatar
looks like u could get a crows foot in there, lossen it a bit, pull the mani forward, loosen it again and repeat
Old Apr 29, 2008 | 06:27 PM
2highpsi's Avatar
I'd hit it up with some PB blaster too, so when you get a good bite on it, it'll be sure to come out.
Old Apr 29, 2008 | 06:28 PM
dremel the exposed stud portion, fit a box end wrench.
replace stud with new stud.
Old Apr 29, 2008 | 06:29 PM
Spoolin18's Avatar
A Turbo socket set, they are meant for things like this . Your local Snap-On, Matco, Mac dealer would have these.
Old Apr 29, 2008 | 06:32 PM
camarokilla's Avatar
that bolt does not look that bad try letting to car run a little to warm it up it will come off easier than pound a socket on there had to do the same with mine
Old Apr 29, 2008 | 06:35 PM
whitey4d's Avatar
I just saw the pic on a bigger screen. I would have to say either the flare/brake line wrench or dremel and box end as stated above. Sorry I didnt see the pic well enough.
