Nice thread off MLR on a 2.3 build with pics (also TS 35R)
Old Jan 11, 2009 | 05:37 PM
blueice288's Avatar
Originally Posted by Ted B
That depends upon your definition of full spool. That could mean anything.
at about 38psi of boost.
Old Jan 12, 2009 | 07:35 AM
Ted B's Avatar
Originally Posted by blueice288
Ted,
i have a 2.3L full built with AEM EMS, 1200cc injectors and running single scroll HTA82. Now i want to upgrade the turbo to the HTA86 but i was considering the TS HTA86 from ETS. What do you think would the power difference be?
I full spool at about 5000rpm with the HTA82 single scroll. With the TS HTA86 when do you think i should expect full spool? And the next question is who should i get the kit from?
38 psi at 5000 rpm with a 2.3L seems slow spooling. If you go to a TS HTA3586, you should be seeing 38psi by around 4000-4200 rpm. You should notice sharper, quicker throttle response as well.
As for Vendors, Full-Race has always been the TS masters, and now ETS has jumped on board.
Old Jan 12, 2009 | 08:08 AM
esevo's Avatar
Ill be done building mine in two weeks JAM 2.3L stg 3 JAM head stg2. AFI TS 35R 1.06. Ill have my own thread, with pics and vid soon.
So congrats to the owner on the perfect setup!
Evan Smith
Old Jan 12, 2009 | 08:17 AM
scorke's Avatar
Evan Smith
My AFI TS 1.06 t4 setup is on its way too, so there will be at least 3 of us
Scorke
Old Jan 12, 2009 | 09:21 AM
crcain's Avatar
That is absolutely nutty and mental spoolup. I see 30 psi at 4500 rpm in 4th gear on an VIII gearbox with a single scroll 35r / 2.4.
I wonder if we will see Buschur do a twin scroll kit in '09. Now that I've seen Ted's results and others I think it's being proven you get about the same gains you do with a stroker as you do from going twin scroll.
Old Jan 12, 2009 | 09:28 AM
Mark S's Avatar
I have a Evo 9 with a FR GT4088 2.2lt pulling 2.6bar at 4200rpm in 5th forgot to try 4th but theres only about 100rpm slower from mem. On UK pump fuel.
Mark
Old Jan 12, 2009 | 09:32 AM
crcain's Avatar
Mark
Mark have you had it on the dyno? If so what were the figures?
LOL at the boost on pump gas.
Old Jan 12, 2009 | 09:36 AM
Mark S's Avatar
Its John RS11 on the Mlr, 659hp and 580ftlb, I am going to run it again on the RR due to the cam not working and we lost ftlb and responce but sorted the issue with the cam moving and found the responce again .
Mark
Old Jan 12, 2009 | 09:37 AM
crcain's Avatar
Mark
Are those DD flywheel estimates or engine dyno figures. On pump gas right?
Old Jan 12, 2009 | 09:52 AM
Mark S's Avatar
Engine dyno.
Mark
Old Jan 12, 2009 | 10:11 AM
crcain's Avatar
Engine dyno.
Mark
The single scroll 35r's you do on the engine dyno normally make about 600 on pump... so the TS 4088r we are talking about now makes about 60 hp more peak power? But spools way better and makes more torque?
Old Jan 12, 2009 | 01:20 PM
esevo's Avatar
Scorke
I guess a total of 5 kits were ordered over the Holidays.
I want the most stock like response with the biggest gains... I think this is the perfect setup.
Evan Smith
Old Jan 12, 2009 | 01:23 PM
scorke's Avatar
Evan Smith
There we go
Kelfords/Vpro are going in too
Scorke
Old Jan 13, 2009 | 03:04 PM
blueice288's Avatar
What do you guys think about an ETS TS with PT6262 compare to the HTA86?
spool time vs HP gains
Old Jan 13, 2009 | 04:33 PM
scorke's Avatar
Scorke
