Ralliart LICP question
Old Apr 30, 2008 | 02:48 PM
bso's Avatar
bso
Just installed my Ralliart intercooler piping. With the upper installed, my car felt very good sop testing. With the lower installed, the cars feels like it lost some lower end torque. This kit is on a stock motor and turbo. I did replace the factory licp nozzle with the larger ralliart nozzle that came with the kit and I used a new gasket to get a good seal at the turbo. I already checked for vacuum leaks with soapy water with no problems found. Would the piping be too large for a stock turbo?
Old Apr 30, 2008 | 02:56 PM
Ph3n1x's Avatar
Assuming the size is matches some of the competitors, it should not hinder performance. Do a proper boost leak test to rule that out.
Old May 2, 2008 | 10:38 AM
bso's Avatar
bso
The LICP comes with a new turbo nozzle that is bigger than the OEM. The pipe and coupling are both straight with no reducer. I'm thinking it could be designed for a bigger turbo setup.
Old May 3, 2008 | 07:27 PM
hytek369's Avatar
do you have any pics?
Old May 3, 2008 | 07:55 PM
CA$H's Avatar
shouldnt this be in the Ralliart forum not the Evo forum?
Old May 3, 2008 | 08:27 PM
hytek369's Avatar
why not? if you are referring to the lancer ralliarts, you need to remember the lancers don't have turbos and ralliart makes products for evos.
Old May 3, 2008 | 08:35 PM
EvoTio's Avatar
Old May 4, 2008 | 08:43 AM
bso's Avatar
bso
Ralliart parts for the Evo....
I found my my problem with the lagging performance. I did not install the primary pill when I changed out the old vacuum line going to the Ralliart J-Pipe.
Old May 4, 2008 | 09:40 AM
Aby@MIL.SPEC's Avatar
I really like the licp set-up of the ralli-art. Mostly due to them providing a very nice discharge pipe that comes with a provision to add a bung.
Now is that picture provided for the evo 8 or 9 turbo?
any chance of you measuring the dicharge pipe i.d. where it mounts to the turbo before the install?
Old May 4, 2008 | 09:59 AM
bso's Avatar
bso
I have it installed on a 8. The piping follows the stock path very well and the part should fit the 9. The J-Pipe turbo side id is same size as the factory gasket. The pipe is made out of thicker aluminum with some room for porting if needed compared to the stock metal tube pipe.
Jameson_IXMR
21
Dec 11, 2016 07:33 PM
peanutcracker1
Aug 11, 2014 06:44 AM
STi_kill3r
Apr 6, 2012 12:13 AM
03evilution
57
Dec 11, 2010 12:40 AM
Biggy VIII
10
Nov 19, 2010 12:56 PM
