My Stock turbo dyno#
I can only hold 19 or 20 at 7000, but remember the cam choice and VE plays a big part in that, if your engine flows more air then the turbo will not build as much pressure against it, so even though the psi is lower, the flow may be the same as someone holding more "boost" to redline
I know you have the 9 turbo though, so you'll end up better than I would nevertheless
I have personally seen the cosi's m3's outperform the Juns. I would be the first to tell you and think that Jun mivecs would be the way to go if you can afford them, and not to say they are bad cams, but I have seen the cosi M3 make more power on a IX then the Juns. IDK and the gsc s2's have a good amount of lift too. The cosis have like 11.8/11.5 on the m3's.
I just moved to E85 on my EVO, it is definitely lots and lots of win!
