3rd gear grind
Old May 6, 2008 | 11:04 PM
Spish's Avatar
3rd gear grind
I just got my IX and I've noticed it sometimes grinds when going into 3rd, does anyone else have this problem? It’s not horrible, just kind of annoying. It kind of feels like when you don't push the clutch in all the way and you get that little grind before it goes into gear. Any help is much appreciated.
Old May 7, 2008 | 04:05 AM
recompile's Avatar
This is pretty common... 5th is usually the worst.
As long as you don't slam it into gear, it should be fine.
Old May 7, 2008 | 12:38 PM
Spish's Avatar
I read over other posts last night about 3rd and 5th gear grinds and was wondering how many people are second or third owners, and did you have a problem getting the warranty work done?
Old May 8, 2008 | 12:32 PM
Henster's Avatar
I just bought a used IX with 17K on it and I've noticed the same thing. I took it to the dealer and they said that when they drove it they didn't notice anything unusual, but there is a known issue with the synchros. They said they would have to tear it all apart to take a look and would have it for a few days, but the warranty still covers it.
I also noticed that the clutch seems to make a slight rattling/humming noise but goes away when I push the pedal all the way and comes back when I release it. Only notice it when I'm parked as it's not too loud. Anyone else got this?
What's the mileage on your car?
Old May 8, 2008 | 12:47 PM
Davo's Avatar
yup got that with an VIII
used amsoil severe gear and reduced alot from mt-90
replaced stoc line with pill to stainless one and grind is gone, go figure
still bought syncros for when bg comes down just to change it
Old May 8, 2008 | 03:34 PM
Jeeperjunior's Avatar
I had a 4th gear grind so when I switched out my clutch I shipped my tranny and had a shep rebuild. Haven't got it back yet.
Old May 8, 2008 | 06:08 PM
Spish's Avatar
I've got 39k on my IX. no problems with the clutch, just 3rd gear.
Old May 8, 2008 | 06:13 PM
EVOLV3D's Avatar
off topic, but when you put the stainless steel braided clutch line does that get rid of the restrictor pill?
Old May 8, 2008 | 06:15 PM
Yes. Restrictor pill is done away with. I'm 90% sure of it.
Old May 9, 2008 | 12:38 AM
Spish's Avatar
Newbie question, but what is a restrictor pill?
Old May 9, 2008 | 01:12 AM
big block ix's Avatar
Try adjusting your clutch engagement point it will solve the problem in most cases bro..
does a lot to cut down on "synchro grindage"
Old May 9, 2008 | 10:52 AM
Davo's Avatar
u can put back in the pill with the ss line or leave out as u would have to remove from old one and put into new ss line
restrictor pill basically limits amt. of fluid going to the clutch
Old May 10, 2008 | 09:55 AM
EVOLV3D's Avatar
How can i find out if its out?
Old May 11, 2008 | 06:44 PM
shannon-evo's Avatar
I have a 9 with 22K miles, no 3rd gear grind.
Old May 11, 2008 | 06:46 PM
SpooksEvo's Avatar
Good times. Gotta love the grinding sycros
