HAFE O2 housing problem
Old Jun 20, 2008 | 08:24 AM
sabastian458's Avatar
I hope so, I just placed an order for them. I tell ya, this kit is starting to nickel and dime me to death. I have spent right at $100 in bolts for this thing.
Old Jun 20, 2008 | 08:27 AM
Originally Posted by marksae
What about castle nuts? Have you thought about those? You can use cotter pins to hold the nuts in place after tightening them.
Not enough room for the nut. It is to tall. When we say it is tight, I mean tighter than a virgin **** And there isnt enough material to drill enough holes thru the stud. The stud is only like 6mm thick
The design of the mani was good in theroy, but they should have realized how hard it is to put the housing bolts on with the first prototype and changed the postion they have the turbo clocked at.
Old Jun 23, 2008 | 09:54 AM
Ok, new studs, new lock washers, new Maryland metric lock washers onto of the nuts on the 2 that keep coming loose with locking nuts ontop of that.
My next step if it comes loose again is to weld the mother f***er, or switch to V-band.
For anyone with the balance shafts removed, large cams, and solid mounts, this kit isnt for you. Go with V-band from the get go.
Old Jun 23, 2008 | 10:10 AM
igo4bmx's Avatar
yeah if u want something that will never loosen by itself, safety wire or
http://www.stage8.com/
i had these in my turbo civic and they are AWESOME
Old Jun 23, 2008 | 04:30 PM
that might work, but the clearance may still be an issue on 1 or 2 of the bolts/studs.
Old Sep 4, 2008 | 06:35 AM
Update.
This has been the longest it has stayed on. Well untill last nite when it completely came off the car. The only thing holding it is the tie bars under the car holding the down pipe, and the studs i put in the turbine housing. I can stick my finger between the turbine housing and o2 housing.
My solution this time is a drastic one. I refuse to fix this thing again. I am welding it. I am done messing with it. I advise anyone else that is planing on runing solid mounts and removed the balance shafts, DO NOT GET THIS HOUSING.
Xska555
Sep 6, 2016 07:56 AM
lancerrally45
Nov 4, 2015 06:39 AM
Seancj
May 3, 2015 02:14 PM
o-townFLA
Nov 12, 2013 10:08 AM
gt40
Aug 19, 2009 11:47 AM
