(MELT-AGE) PULSTAR PLUGS you've NEVER SEEN BEFORE Guaranteed
Old May 16, 2008 | 11:36 AM
o-townFLA's Avatar
Have you contacted Pulstar yet? That wouldve been priority #1.
all in all I hope everything works out...
Old May 16, 2008 | 11:48 AM
codean's Avatar
He isn't the only person that I've seen have problems with these plugs. While they do give a better spark and dyno proven HP, the plug isn't tough enough and ends up self destructing.
Evo9"Miss Rose"'s Avatar
Originally Posted by wreckleford
Are you sure this was caused by the plugs?
Any piston, cylinder wall, turbo damage as a result?
no piston damage maybe a lil scratch here and there on top of the piston, cylinder wall due to being TDC i gotta turn the crank to see it but having issues due to timing belt still on with cam gears, and highly doubt my turbo took a dump either.
Old May 16, 2008 | 11:50 AM
Originally Posted by spdracr
looks like NASTY detonation how did the car run prior to the melt down was it misfiring at all. any bogging or anything that would suggest the plugs were misgapped. wat octane and did u run meth or water?
misfiring and shaking of the engine. plugs were not misgapped 100% sure they werent i work on cars and as a career and the gap was within specs prior to installing them. and NO METH nor Water, straight 91 pisstane
Old May 16, 2008 | 11:53 AM
sabastian458's Avatar
Do you have an ignition box of some sort on your car? It looks like the spark generated by the Pulstar plugs is too strong/hot and it is melting the grounding strap.
I am very glad I saw this thread. I will keep purchasing the NGK coppers. Sorry for your loss.
Old May 16, 2008 | 11:54 AM
^thats wat im saying i think its just bad detonation
if it was bad deontation then i should have gotten it bad long time ago with my stock plugs. My car ran fine with stock plugs all the way untill i changed them. but i may be wrong as well who knows.
Old May 16, 2008 | 11:57 AM
no sir no ignition box!! im glad im being help to my fellow members. yea it sure does suck not driving my EVO. But i guess i can look at it this way (i finally get to to ship it do Bushur racing and get it upgraded) i just wish PULSTAR will help me out in some sort of way.
Old May 16, 2008 | 12:00 PM
Originally Posted by cfdfireman1
What does the top of that piston look like? Are you sure the plug did that to your engine or did the engine do that to the plug?
top of piston looks fine and dandy, i will post up pictures of the pistons,cylinder walls soo ya'll can check it out. im almost sure that the plug did that to my engine and not the other way around.
Old May 16, 2008 | 12:04 PM
Jeff_Jeske's Avatar
You don't melt a valve with bad spark plugs.
Old May 16, 2008 | 12:08 PM
fostytou's Avatar
EvoM Community Team
so... did you take them up on their guarantee? I'd be calling execs a couple of times a day until they did
Old May 16, 2008 | 12:09 PM
mrmefodman's Avatar
Bro you put the wrong size in your car, and you wonder why you had problems.
Old May 16, 2008 | 12:22 PM
He has an Evo 9 plug. The valve broke, not melted. The plug melted.
Old May 16, 2008 | 12:33 PM
SuPeRNeT's Avatar
OMG i would S*it.. That sucks!!!
Old May 16, 2008 | 12:54 PM
dude's Avatar
That looks like a seriously long threaded body...is that the same length as stock???
Granted I have an VIII and not a IX, but my plugs aren't nearly as long as that. Anyone with a IX care to vouch on how much longer the IX plugs are???
Old May 16, 2008 | 12:55 PM
94AWDcoupe's Avatar
clearly pre-ignition damage. Completely different than detonation damage. pre-ignition damage is when normal like spark occurs at the wrong time. usually caused by something glowing in the chamber. In this case its clear the heat range was way too hot. The straps are turning blue from the heat. damage caused by pre-ignition is vastly different than detonation damage as well. You can see there is not damage to aluminum parts. detonation attacks pistons and cylinder head by allowing extreme heat to enter those parts at or near TDC. The type of damage we have hear is when you have ignition way before TDC this makes tremendous combustion heat but not at TDC specifically. In turn the valve melts as this exteme heat is expelled from the chamber.
definitely ruined your engine installing these plugs. hopefully they will do something about it, but It will be an uphill battle. hopefully your misfortune will save others from making the same mistake.
