Royal Purple Synchromax?
Old May 16, 2008 | 12:59 PM
Hmoneybagz's Avatar
I just bought 3 quarts of this stuff for my evo. Does anyone have any experience with this stuff? I tried searching, but all i found were threads from 05 and 06 talking about the regular royal purple trans fluid. I dont know if I should return this stuff and just buy redline oil? Please help guys! Thanks
Old May 16, 2008 | 03:33 PM
Hmoneybagz's Avatar
bump! anyone use this stuff?
Old May 16, 2008 | 04:00 PM
joehoo's Avatar
bump for more info. I use the oem stuff but looking for a aftermarket fluid option
Old May 16, 2008 | 04:07 PM
bluebyu36's Avatar
return it and buy redline royal purple will damage your syncros,trust me had many friends damage there trany with that junk,get mt90
Old May 16, 2008 | 04:26 PM
wshihdnevo's Avatar
^dito! I actually have been running the royal purple syncromax and it works, but when its cold it takes awhile to work, otherwise its fine, but I will be switching to redline this summer, also in my rear diff too.
Old May 16, 2008 | 09:06 PM
Hmoneybagz's Avatar
Thanks guys! Which Redline trans fluid do i get? mt90, 75w90, ect...?
Old May 16, 2008 | 09:07 PM
bluebyu36's Avatar
if u want 2 quarts of mt90 and 1 quart of heavy shookproof if not just mt90
Old May 17, 2008 | 03:29 AM
OldschoolEVO's Avatar
I've been using RP for over 4yrs in three different Evos. All tracked with no problems whats so ever. Even used it in my AYC equipped Evos with no problem. Learn how to drive
Old May 17, 2008 | 04:01 PM
hanahawaiian's Avatar
i use AMSoil Manual transmission Gear oils... it amazed and used alot drag and road race never had broke.. i have over 48k miles and 3 change with AMSoil...
Old May 17, 2008 | 04:08 PM
Chemwarrior's Avatar
I switched from Royal Purple to Redline MT90 with a splash of Heavyweight and my transmission has never shifted smoother. I was having problems with the infamous 5th gear grind and now it is gone. I would highly advise this as a transmission fluid.
Old May 17, 2008 | 04:28 PM
Wicked E's Avatar
Ask Brad from Mellon Tuning what happened to his car with this stuff...
-E
Old May 17, 2008 | 05:17 PM
Hmoneybagz's Avatar
Thanks guys! I appreciated the help!
Old May 19, 2008 | 06:43 PM
Hmoneybagz's Avatar
Anyone else use this stuff?
Old May 19, 2008 | 08:13 PM
vwjeff's Avatar
I use the GL5 RP Gear Max... 2 seasons and going strong. When Dan Buschur had my trans apart to replace my sycro's (just cause my engine was out, and why not), he called me and said "what the hell is this purple slime?" "the gears dont even look worn" . Lets just say he was like.... WOW (and in a good way)!
Oh yeah and +1 on the learn to drive
Old May 19, 2008 | 10:41 PM
codean's Avatar
I used RP syncromax in my 1999 BMW M coupe a few years back. It was great for about a week, then the transmission just got notchy and unpleasant to shift.
Stick with redline MT90, amsoil GL4 gear oil, or stock diaqueen for the EVO
