clutch ?
Old May 21, 2008 | 12:40 PM
boostedfirefly's Avatar
clutch ?
i got a prolite XACT flywheel, ACT 6 puck clutch with Xtream pressure plate about 1600 miles ago. right now, the clutch doesn't release until the pedals almost at the top. can this just be an adjustment issue or did i already screw up my clutch? what would i look for if the clutch was screwed up? As of right now, it doesn't slip.
Old May 21, 2008 | 07:12 PM
PTevo's Avatar
You need to adjust it so there is free play at the top, otherwise it will prematurely wear out - saying this from first hand experience.
Old May 21, 2008 | 07:17 PM
ok. so let's pretend like i'm a girl who's only had autos b4. what does free play mean?
do u mean to make it grab earlier like mid way?
Old May 21, 2008 | 07:33 PM
cfdfireman1's Avatar
free play at the top means the pedal will move with very little effort before it gets resistance and actually moves the clutch plate.
Old May 21, 2008 | 07:51 PM
how long b4 having the clutch release at such a high point will the disc start to
have issues?
what i'm thinking is that since the clutch is released at such a high point that even while the clutch pedal is released, the pressure plate still has pressure on it and then the clutch wouldn't be fully engaged.
how do u kno if the clutch is not engaged fully?
or is that just a stang thing? lol.
Old May 22, 2008 | 02:12 PM
Well is there "free play" of not?
Old May 22, 2008 | 03:19 PM
now there is.
Old May 31, 2008 | 10:36 AM
High_PSI's Avatar
Then find a man to take care of you and tell you that "it's alright, lemy take care of it baby.." And then service him like a good girl should.
Old May 31, 2008 | 10:56 AM
EVIL MR's Avatar
it will sound crazy to you but adjusted to be just a high as you brake and it will work better.
J187SD
Jul 23, 2013 11:51 PM
MitsuJDM
23
Feb 23, 2013 02:07 AM
evogottago
Aug 16, 2008 03:33 PM
bbyevo8u
Aug 11, 2007 04:55 PM
Evo3GEclipse
15
Jun 14, 2007 05:06 PM
