whats the best spark plug to get?
Old May 25, 2008 | 09:57 AM
bbyevo8u's Avatar
i'm going to change out my srapk plugs can someone tell me witch is the best one to get or should i just go with oem stock plugs, and what should i gap too?
Old May 25, 2008 | 10:02 AM
flyingwangwang's Avatar
NGK BPR7ES. They're copper but for turbo'ed cars, they're better compare to Iridum plugs. For IX gap them at .20-.24
Old May 25, 2008 | 10:05 AM
evo_08's Avatar
those wont work on a 9.
Old May 25, 2008 | 10:06 AM
EvoKnievo's Avatar
o.e.m
expensive, but good.
Old May 25, 2008 | 10:31 AM
recompile's Avatar
Originally Posted by EvoKnievo
o.e.m
+1. Stay with OEM NGK plugs on the IX. Don't think twice about them until the day you have spark issues.
Old May 25, 2008 | 10:34 AM
bbyevo8u's Avatar
what oem gap?
Old May 25, 2008 | 10:42 AM
bbyevo8u's Avatar
well i only have about 16k miles on the car! when do you recommend i change them out?? how often do you guys change them
Old May 25, 2008 | 10:55 AM
BGR's Avatar
BGR
Stick with the factory NGK spark plugs. I have a set used less than 100 miles - PM me if you want them.
Old May 25, 2008 | 11:03 AM
bbyevo8u's Avatar
is it too early to change them out at 16k miles???
Old May 25, 2008 | 11:11 AM
BGR's Avatar
BGR
I think its recommended at 30K but I would change them more often since you are boosing above factory levels.
Old May 25, 2008 | 11:14 AM
BGR's Avatar
BGR
Factory plugs are already pre-gapped so just swap but be careful of not hitting the tips.
what oem gap?
Old May 25, 2008 | 11:36 AM
smarsenal's Avatar
^+1 The IX plugs are longer than the VIII plugs. Best to use the factory NGK Iridiums that are pre-gapped.
Old May 25, 2008 | 11:40 AM
ak47po's Avatar
Old May 25, 2008 | 12:08 PM
Akisan2's Avatar
I replaced mine at 20k and I boost around 24 constantly. The plugs looked good, but it's good to swap out anyways. OEM +1
Old May 25, 2008 | 01:01 PM
krazirob's Avatar
i replaced mine once i started have spark issues.....got the IHK24's.....
no need to change to upgraded ones if you arent pushing lots of power.....
