Forge Motorsports BOV
Old Aug 13, 2003 | 08:17 AM
BluEvo3037's Avatar
I was looking at the install page for the Forge Motorsports BOV, just to make sure mine was on correctly...As i read the last part of the install..I realized that mine was put on incorrectly or in otherwords..the bov was mounted opposite of the way it was suppose to be....
I was wondering if this would cause any problems to the engine??
Please post...I am very concerned..Thank you..
-John
Old Aug 13, 2003 | 09:39 AM
bs's Avatar
bs
no problems. it has been shown that the forge bov can be mounted in either orientation. the same orientation as the stock bov is the preferred way though.
Old Aug 13, 2003 | 02:48 PM
BluEvo3037's Avatar
So that means...The BOV can be mounted in either hose...and it wont' hurt the turbo??
-John
Old Aug 13, 2003 | 04:04 PM
ForgeMotorsport's Avatar
Which BOV are we talking about first? The recirculating, aka diverter valve, or the actual VTA BOV. The VTA cannot be mounted in both hoses as it needs to be on the pressure side of the turbo.
Old Aug 13, 2003 | 10:49 PM
BluEvo3037's Avatar
I have the actual BOV..VTA...
Old Aug 13, 2003 | 10:50 PM
BluEvo3037's Avatar
I plugged the other hose...Not the bottom one..The one of the side...That hangs.
Is it bad if i had it like that b4?? If so, how much damage would it have caused??
-John
Old Aug 14, 2003 | 05:19 AM
SuperchargedGTZ's Avatar
That is bad. I think If I understand you correctly you mounted the BOV on the intake tube in front of the Turbo. If so, than yes, that is extremely bad because you then essential have no Blow off since you plugged up the hole on the intake tube leading to the throttle body.
Old Aug 14, 2003 | 06:56 AM
bs's Avatar
bs
oops....i misunderstood. i thought you meant the diverter valve. as stated above you will want the bov on the pipe leading to the throttle body. fyi i believe there are actually instructions on installing the VTA bov on this website under project evo......sound like you may want to check it out.
Old Aug 14, 2003 | 08:33 AM
BluEvo3037's Avatar
I did already..I fixed my BOV..But i want to know, if any harm was done to my car having it mounted the other way..
-John
Old Aug 14, 2003 | 10:36 PM
Red C5's Avatar
Don't worry about it now. What's done is done.
How do you like the BOV?
Old Aug 15, 2003 | 07:52 AM
BluEvo3037's Avatar
Haha..If my engine blows up...Whats there not to worry about?? Bah...Its pretty cool..Its a different sound..never heard it b4...
-John
Old Aug 15, 2003 | 03:44 PM
N10S's Avatar
-John
How long did you run it that way?
Realistically the DV valve is a safety mechanism to keep boost back-wash out of the turbo when you let off the gas between shifts. This keeps the turbo stalling to a minimum between spools, and supposedly helps ensure less load on the turbo and longer turbo life overall. After all if the pressure isn't flowing into and out of the heads to the exhaust, it has to go somewhere and that is either out a DV/BOV or back against the turbo impellar.
That said My Syclone doesn't have a DV or BOV, and instead anytime you chop the throttle you get major impellar chop noise as the turbo deals with the sudden change in air flow. Who needs a VTA when you can scare the population with a simple open air element!
BTW- I am on my second engine in the Syclone and still running the same turbo which still looked great and was clearance checked for end play and still well within spec.
Bet you were thinking your VTA was a dud eh?!
N10S
Kevin Knight
Jul 27, 2007 10:00 AM
jeff45
Sep 26, 2006 11:28 PM
badlooser
Oct 11, 2005 05:49 AM
rblader86
May 9, 2004 01:19 PM
w2pac12345
39
Jul 8, 2003 08:50 PM
