compression test on a used evo
Old May 30, 2008 | 05:25 PM
deadbeatrec's Avatar
so my buddy bought a used evo 9 and there is a little blue smoke coming out of the tail pipe at wot. so i am going to help him figure out this dilemma.
so some of the things i need to know are....
1. what the stock compression should be in PSI on a stock evo
2. what fuse to take out to disable the fuel pump so when doing the compression test we dont fill the cylinders with fuel
also after i do this i will be checking to see i the turbo is spitting oil. will be checking the intercooler and pipes.
so if anyone can chime in and answer some of these quesions, that would be fantastic! also make any sugestions.
i will be doing a boost check as well just to make sure he has no leaks.
thanks!
Old May 30, 2008 | 05:50 PM
Exciting News's Avatar
thanks!
1. For a IX it's about 145
2. No need. Just disconnect the cam angle sensor. Look for the triangle connector near the right side (if you're facing the firewall) of the valve cover area.
Remember, do it with the engine warm and with the throttle wide open. Crank it until about 5 Mississippi and you're good.
Old May 31, 2008 | 03:55 AM
so just disconect the sensor and we will be good? that stops fuel from spitting?
ok i will do, thanks.
any other sugestions to look for?
Old May 31, 2008 | 06:14 AM
That is correct. Your injectors won't fire with the CAS disconnected. It's pretty easy to do. Make sure the tester is threaded snugly but don't ham-fist it. Those aluminum spark plug threads ain't the strongest things on the planet.
Good luck.
Old May 31, 2008 | 06:44 AM
Good luck.
I a write up that said to disconect the crank shaft pos sensor, im assuming both will work.
Old May 31, 2008 | 06:47 AM
scottatyamaha's Avatar
Is this car modded?
Old May 31, 2008 | 06:57 AM
packrat's Avatar
You could probably just pull an ecu fuse. If there is no primary ignition, there will be no fuel injector pulse. This way you can avoid a check engine light after your done.
Old May 31, 2008 | 07:52 AM
the car is stock as far as i know
and what ecu fuse? u have to be a little more specific here as i have never done this to an evo, only older cars and a svt focus.y would it pull a check engine light?
Old May 31, 2008 | 08:04 AM
gsrboi80's Avatar
It might because your trying to turn the car over with the cam sensor disconnected. Just reset it when your done no biggie
Old May 31, 2008 | 08:28 AM
very true. i will if he gets a code.
but i have a built 9:1 motor in my evo, i wonder what my compression will be. like 175+ i bet. im courious now and i might just do mine.
Old Jun 1, 2008 | 08:50 AM
https://www.evolutionm.net/forums/sh...mpression+test
nice little how to incase anyone cares
J8dailo
Mar 1, 2017 10:08 AM
EVIL_EV0
11
Sep 19, 2014 05:27 AM
kapolani
33
Apr 8, 2008 03:01 PM
mikespike2
May 14, 2007 09:58 AM
hova00
21
Oct 30, 2006 02:52 PM
