im going to be running 400hp
Old Jun 1, 2008 | 07:06 PM
MR.IVMR2YOU's Avatar
question is what clutch will suite me the best. it is my daily driver. I don't mind the clutch being stiff pushing harder doesn't really bother me but, i dont want the clutch to feel like im going to grind a gear or not lock into place when im downshifting if you know what i mean? with that been said i was thinking od the exedy twin... if i have to pay money for something that isnt going to give me problem in the long run im all about that. thanks.
Old Jun 1, 2008 | 08:54 PM
Burklow's Avatar
If you can afford it, go Exedy Twin.
If you can't, go ACT HDSS with street disk. Make sure you adjust the clutch pedal.
I would add a SS clutch line at the same time.
Old Jun 1, 2008 | 09:07 PM
chaotichoax's Avatar
torque is what you base a clutch decision off of
you need to tell us more about your planned set up to give you a truly accurate answer
Old Jun 1, 2008 | 09:30 PM
BlackTypeS's Avatar
lol your going to be "running" 400hp
Old Jun 1, 2008 | 10:57 PM
OK here's my setup half the parts are in my closet the other half is on the way to my front door.
FP Green turbo
ported housing and 18 psi wastegate
turbine house porting
walbro 225 fuel pump
arp head studs
greddy 720cc injectors
Nesie LICP
test pipe
invidia turbo outlet
HKS 272/10.8IN 10.2 CAMS
HKS Hybrid filter
Defi red race 52mm boost gauge
GM boost solenoid
Tune by :Reese tuning
ok so my question is what clutch should i get. I only have 8K on the stock clutch. i was thinking of the exedy twin b/c i do have the money.
Old Jun 1, 2008 | 11:09 PM
EvoHung's Avatar
FP Green turbo
arp head studs
Nesie LICP
test pipe
HKS Hybrid filter
GM boost solenoid
I believe you answered your own question.
Old Jun 1, 2008 | 11:16 PM
haha ok well then allow me to rephrase.... has anyone had first hand experience with this clutch "exedy twin"...if so, will i have to make adjustments to my clutch. and did you ever feel any thing less in performance compared to your stock clutch, meaning having a hard time finding a gear, notchiness while downshifter or shifting in general, or any problems at all. thanks.
Old Jun 1, 2008 | 11:17 PM
fugiwara's Avatar
what's the difference between exedy twin vs act hdss, most people recommends these two.
Old Jun 1, 2008 | 11:27 PM
EvoHung's Avatar
My cousin had a 2.3 gt35r powered Evo equipped with the twin. I had absolutely NO problems whatsoever shifting gears. Very light pedal effort.
Old Jun 1, 2008 | 11:29 PM
Warrtalon's Avatar
Probably hundreds if not thousands of Evos who have used it, so there are TONS of threads/posts with info regarding it, and it is the most recommended one there is.
I use it personally, and I think you have it backwards asking if it has anything LESS in performance compared to stock. The only thing the stocker has is a light pedal.
Old Jun 2, 2008 | 12:30 AM
importjake00's Avatar
well said, and holy shlt u have a lot of posts
Old Jun 2, 2008 | 05:26 AM
Done's Avatar
I have very mixed thoughts about a twin. They are very noise and expenisve. If its a daily driver I would go act. I had a tilton twin in my integra "suppose to be the best clutch money could buy at the time", I never launched and only got 5k miles out of of before the splines of the disk went out. Cost $500 to repair just in parts.
ohYouEvo
Aug 28, 2016 10:58 AM
heel2toe
30
Mar 15, 2016 12:54 PM
03redtype-s
Dec 14, 2015 05:43 AM
ugakirk
14
Apr 14, 2011 09:11 PM
WolfsFang
25
Dec 28, 2010 02:05 AM
