compression test results
Old May 31, 2011 | 10:41 AM
  #76
BigT's Avatar
I hate it when people tell you to add a little bit of oil to check if your rings are bad. Um, if you add a little bit of oil to a motor with perfect compression, guess what, the compression still rises. So, are the rings bad on a perfect motor? No, the oil itself just adds slight compression and increase the seal of the perfectly good rings.
The only thing you can do is a leakdown test and that will only tell you if you have an excessive leak. The only true way to know if your rings, or valves or whatever it may be are bad is to open up the motor.
DuBBzEvo27
Jun 29, 2015 10:00 PM
steven121
Aug 16, 2013 08:05 AM
Kracka
77
Jul 24, 2013 01:45 PM
Throttle
20
Jan 21, 2012 07:41 AM
KevinD
11
Oct 4, 2006 06:18 AM
