Mirage VR-X JDM Spec
Old Jun 10, 2008 | 06:18 PM
andrewzaragoza's Avatar
put in the evo 8 turbo and just watch your afrs. but you would definitely need a tune. try researching if your ecu is reflashable. try openecu.org. if not then it would be good to try an evo ecu. when swapping ecus just make sure you have an ecu pinout diagram for both ecu just to make sure they match. i remember seeing some 4g93t in a surplus shop and don't they have mivec on it?
Old Jun 10, 2008 | 06:21 PM
Johnny Fargas's Avatar
Nice, I like it a lot!
Old Jun 10, 2008 | 07:54 PM
94AWDcoupe's Avatar
Engine pic please!! and what is chassis code?
Old Jun 10, 2008 | 09:03 PM
luvnish's Avatar
Chassis Code is CM5A
Engine pic will be up tomorrow, gonna take some pics in the morning
The ECU is not flashable, I'd have to do the same thing that Evo5 and 6 owners do and get a 7 or 8 ECU for any kind of reflashing.
Old Jun 10, 2008 | 11:46 PM
luvnish's Avatar
Nope no Mivec, The Mivec in the same body as mine, is the 4G92 1.6L engine, and comes FWD, rated at 175 bhp from Mitsubishi Japan.
I know many Aussie and NewZealand guys have put the Mivec head from the 1.6, onto the 1.8L 4G93 turbocharged block with some sort of stand alone EMS with Mivec support. They've had a lot of success but as of right now I'm not very familiar with Mivec and what it entails to get it to work on the GSR 1.8T bottom end.
Old Jun 11, 2008 | 11:16 AM
luvnish's Avatar
Engine Bay pics added.
Old Jun 11, 2008 | 03:20 PM
94AWDcoupe's Avatar
man I wish I could get my hands on one of those. I like it...
Old Jun 11, 2008 | 09:00 PM
hytek369's Avatar
thats a really cool car. should be a fun project
Old Jun 15, 2008 | 12:36 AM
luvnish's Avatar
ok guys, tactrix cable is on the way.
any recommendations for good datalogging software? remember i'm using an Innovate LM1 wideband.
Old Jun 15, 2008 | 06:58 AM
MitsuJDM's Avatar
I love it! I have a 2002 Mirage coupe that I did a custom turbo set-up on I love these cars!
Old Jun 15, 2008 | 07:12 AM
vmrevo9's Avatar
Veteran: Air Force
nice car!!
Old Jun 15, 2008 | 07:21 AM
jmelocik's Avatar
I prefer Mistulogger but thats just me. It seems to be more accurate for logging the fuel trims and such and it has support for a good number of widebands.
Josh
Old Jun 15, 2008 | 09:35 AM
wreckleford's Avatar
I'm pretty sure the pins on the evo7 or 8 ECU are identical or nearly indentical to the pins on my harness. I am currently using an evo8 boomslang harness for my safc2 and it works fine. Anyone ever experience problems using a 7 or 8 ECU on another version Evo?
The 7/us8 ecu will work but a few wire changes are necessary as with the 4/5/6. I have done it on a 1997 Lancer GLX previously. The most difficult part will be getting the MAF compensation and injector compensation right. Since you might be doing an E-flash, it would be easier/quiker to just get Evo injectors and MAF.
Old Jun 15, 2008 | 09:38 AM
4g63smokinall4s's Avatar
very nice
Old Jun 15, 2008 | 10:10 AM
luvnish's Avatar
Can the MAF and ECU be used interchangeably between the evo7 and 8?
Thanks for your input, makes a lot of sense to use all evo components, it will just run pig rich, then it's time for a tune.
