Transfer case
Old Nov 11, 2008 | 10:16 PM
huevosrancheros's Avatar
Originally Posted by gfng
how can u possibly overfill it if it will , release the oil when it completly full ??? i dont see how uu can over fill it
you cant' it'll just spill out LOL.
Old Aug 28, 2011 | 10:39 PM
desiromeo812's Avatar
It can be over fillled if you fill it from the drain hole, Since that would be the best way to fill it anyways..
Fill it from bottom with one quart.. obviously make sure the fill plug is in... Drive around the block..Level car and remove fill plug.. All the excess fluid will come out and level will be perfect.
Old Aug 29, 2011 | 08:50 AM
barneyb's Avatar
Simple. Use a hose about the same size as the threads in the fill hole, pump in too much oil and yank the hose and insert the plug.
The least experienced guy in the shop is going to be the guy on the lube rack.
TomekEVO
May 30, 2015 03:27 PM
kevster907
Oct 5, 2014 08:41 PM
Evoshadow
May 22, 2011 03:56 PM
letMeIn
15
Jul 30, 2010 02:40 AM
Kierkegaard
Apr 10, 2007 07:52 PM
