I bought a ETS mini battery kit and the positive terminal does not fit snug to the p
I bought a ETS mini battery kit and the positive terminal does not fit snug to the positive terminal on the car does anybody have this issue? If i pull up the terminal from the car is not even holding on to the positive terminal on the mini battery.
There should be two different size terminals on the battery. The pos is larger than the neg. See if the terminals are the same size or if they are possibly reversed. Did you neg cable go on easy or did you have to stretch it to get it to fit?
The positive terminal is slightly larger than the negative terminal but when i go to tighten the positive terminal from the car to the pistive terminal on the battery it doesnt fit tight, if i pull up or when i go to check if its tight by moving it side to side its not and the psitive terminal from the car moves around on the positive terminal on the battery. Is that how it is with the mini batteries?
SCAMMER! I can't believe I got scammed. I sent money to assembeldbygod for his FMIC almost a month ago. Still no word. Said he was on vacation and shipped it out when he got back on the 20th. Stated he was busy and forgot to write down the tracking number. So no tracking #. He won't even tell me which carrier company he used.
SCAMMER!SCAMMER!SCAMMER!SCAMMER!SCAMMER!SCAMMER!SC AMMER!SCAMMER!SCAMMER!SCAMMER!SCAMMER!SCAMMER!
BaLListic_EVO
Aug 7, 2018 10:22 PM
bnr34rb26dett
10
Dec 12, 2010 07:29 PM
