Best spot for Wideband & Egt Gauges???
Old Jun 18, 2008 | 12:06 PM
dirty0513's Avatar
Just purchased an AEM wide band and some Defi gauges and was need some input on the best location for the o2 and the egt.
Thank in advance.
Old Jun 18, 2008 | 12:10 PM
gsrboi80's Avatar
Most will tell you tap runner 1 for the EGT and no more than 12in down stream on the down pipe anywhere between a 10 - 2 configuration
Old Jun 18, 2008 | 12:17 PM
dirty0513's Avatar
So I can put the egt sensor on the downpipe?
Old Jun 18, 2008 | 12:20 PM
Mr. Evo IX's Avatar
My DP has a EGT bung but I was wondering if it would work there. It's a Tanabe dp, at least I think it's an EGT bung.
Old Jun 18, 2008 | 12:47 PM
gsrboi80's Avatar
No the EGT sensor bung needs to be tapped into the manifold (well it should if you want accurate EGT's). Usually runner 1.
The O2 sensor bung will get tapped into your down pipe
Old Jun 18, 2008 | 12:53 PM
04gsna's Avatar
I have my wideband installed in the location on my second o2 sensor in the downpipe. is that a good location or no?
Old Jun 18, 2008 | 01:12 PM
gsrboi80's Avatar
As long as you dont have a cat it'll be fine
04gsna's Avatar
nope no cat just a straight downpipe
Old Jun 18, 2008 | 01:19 PM
selp's Avatar
EGT sensor like stated above should be at the manifold if you want accurate readings. normally in the 2nd runner.
wideband sensor should be optimally no further than 12" below from the turbo, i have mine at the test pipe and works wonderfully.
Old Jun 18, 2008 | 01:52 PM
gsrboi80's Avatar
Itll be fine there. Most companies will tell you 12in down from turbo on the O2
Old Jun 18, 2008 | 02:01 PM
slicedbreadno2's Avatar
My friend is doing this I'll let him know.
Old Jun 18, 2008 | 02:52 PM
93GSR1's Avatar
the A piller
Old Jun 18, 2008 | 03:31 PM
dirty0513's Avatar
Now tapping the manifold, is it somthing hard to do??
Old Jun 18, 2008 | 03:35 PM
EatSleepBoost's Avatar
not really however if you have never drilled and threaded a hole before it is easy to mess it up. let somebody who has done it before do it.
Old Jun 19, 2008 | 04:22 PM
Mr. Evo IX's Avatar
keep in mind everything that falls in your manifold when your drilling your runner will be going through your turbo if you don't get it out.
