Anti-Lag
Old Jun 25, 2008 | 05:32 AM
  #31
tjordan06's Avatar
so what if you do have a standard equiped ALS (my evo 7 has it) how do you uninstall it?
Tim
Old Jun 25, 2008 | 03:20 PM
  #32
evo_what's Avatar
Tim
evo vii's never came with anti-lag as far as i know. are you thinking of launch control?
-Chris
Old Jun 25, 2008 | 03:39 PM
  #33
mrfred's Avatar
-Chris
JDM Evo VII's did come with anti-lag. There is some additional hardware and the ECU has programming to make use of the hardware. Its been discussed quite a bit in the ECUFlash forum.
Old Jun 25, 2008 | 05:37 PM
  #34
MRfabolous's Avatar
i mean aem system has a anitlag can we use that just for racing purposes? would it be that harsh on the turbo? no1 really launches there car everyday on the street. dyno flash, bushur, ams turbotrix what launching aid at the track to spool up those big turbos?
Old Jun 25, 2008 | 09:34 PM
  #35
mrep32u's Avatar
bump[][][]
Old Jun 26, 2008 | 06:22 AM
  #36
tjordan06's Avatar
well after a little more research it seems as if it is actually a toned down versions of anti lag known as "turbo assist".... it is a metal line that runs directly into the exhaust manifold... does this sound correct?
Old Jun 26, 2008 | 07:32 AM
  #37
evo_what's Avatar
they use a 2-step to build boost before the launch, and some might use nitrous to spool on the launch.
-Chris
Old Jun 26, 2008 | 08:23 AM
  #38
chuntington101's Avatar
yeah thats it and it dose NOTHING to help spool the turbo! lol you would need a much bigger and better setup to make any real life imopact on trubo spool.
Chris.
Old Jun 26, 2008 | 08:27 AM
  #39
wreckless969's Avatar
Id like someone from BR or something to come in here and share there thoughts on this
Old Jun 26, 2008 | 08:40 PM
  #40
MRfabolous's Avatar
me too because i just dont see anyone with a bigger turbo gt35r or bigger spooling it up with a 2step i mean a 2 step on a stock turbo only builds 7-8 psi maybe a little more and that turbo is way smaller then a 35r
Old Jun 27, 2008 | 12:19 AM
  #41
you have to remeber that turbos only make boost when you start to load the engine. thats why the V8 gusy run trans brakes to hold the car so they can load the engine and get the trubo(s) spooled.
it would be intresting to see what a true anti-lag/launch control system could do on an evo. i know you can buy launch controle kits that cut spark on launch (as the car is moving) to minimise wheel spin and maximise traction. wonder if the launch controle stuff in the Motecs works the same?? or if it just redards ignition like the anti-lag dose??
cheers
Chris.
Old Jun 27, 2008 | 08:26 AM
  #42
evo_what's Avatar
here's a vid of the silver AMS evo making 15psi off a 2-step on a 42R.
http://www.youtube.com/watch?v=YoskZooXxIM
-Chris
Old Jun 27, 2008 | 10:06 AM
  #43
Now I know this is true for the most part, but doesnt tuning the ECU usually change that factor? Which is why you can build boost using the 2 step?
Or am I misinterpreting who that works?
Old Jun 30, 2008 | 05:22 AM
  #44
i have heard mixed things. some say that anti-lag is loading the engine, orthers disagree!
at the end of the day your engine will be at full chat with a 2step or a anti-lag launch contole. the throttl;e will be fully open and the engine will be trying to consume as much air and fuel as possable. all you are doing is using the spark timing to "hold back" the engine.
sorry i cant help more. hope someone can though??
Chris.
Old Jun 30, 2008 | 07:26 AM
  #45
TurbotrixRacing's Avatar
-Chris
No we actually use anti-lag for spool .. Brandon comes out on a bit of boost..
You can control how much boost you want to leave the line with .. its violent LOL
mark
turbotrix
