Buschur pipe with CEL
Old Jun 21, 2008 | 03:36 PM
Protostar1's Avatar
I recently installed a test pipe from BR in place of my cat. I had thought that the Buschur midpipe already had a mechanical CEL fix welded in place, and I can tell that there is a spacer there. I had the pipe on for a good week+ with no CEL. Then, yesterday, I hit the track and ran it pretty hard for a while and after pulling off I noticed the light was on. It is staying on now.
My question is: should I get a de-fouler and that will fix the problem? If so will the de-foulers mentioned here in other threads work or is there a different part number required to work with the existing bushur fix?
Or is it simply that running at the track produces a larger quantity of particles then street driving due to higher constant revs and the sensor is now dirty? If that is the case should I clean it or just reset the battery?
Thanks a lot!
Old Jun 21, 2008 | 03:44 PM
RevMoto's Avatar
this might not be from the test pipe. Get a code reader. If you hit your limiter a couple of time it will throw a code.
Old Jun 21, 2008 | 03:52 PM
Protostar1's Avatar
Where is the stock limiter in the IXs? because it is not at 7000 or 7500 I dont thing. And unless it is truely a limiter (I thought there were two types of rev 'limiters' ones that limit a rev max electronically and others that simply cut the engine whenever a rev max is hit) I have not hit it. I only say this because I never hit a point where the motor sounded like it was being cut and you get the brap-brap-brap noise.
Regardless, should I just reset the battery to see if the code disappears and reappears or not?
Old Jun 21, 2008 | 03:59 PM
RevMoto's Avatar
I would be curious to see what the code is. Normally advanced will read it for free. Many things can cause a code.
Old Jun 21, 2008 | 04:22 PM
kreionic's Avatar
If it is the rear o2 just disable it in the ecu. Then no worries about any antifouler etc..
Old Jun 21, 2008 | 04:37 PM
vaflyboi757's Avatar
i got the same CEL when i gutted my CAT, getta code reader to make sure every thingz str8, but i probably wouldnt worry too much
Old Jun 21, 2008 | 07:18 PM
t mac's Avatar
reset the ecu by either disc the battery or pulling the ecu fuses for a few secs and see if it clears it, if not have the CEL code checked at auto zone
Old Jun 21, 2008 | 08:13 PM
David Buschur's Avatar
Yes, the first thing you need to do is read the code and make sure it's from the cat.
Old Jun 24, 2008 | 05:59 PM
Protostar1's Avatar
Thanks much guys, Ill hit up autozone asap.
Old Jul 5, 2008 | 06:13 PM
Protostar1's Avatar
Thank you AMS for the read, ya it was a catalytic inefficency code... If I get a tactrix cable in combination with a generic OBDII read program, will I be able to analyze and erase codes like this from my laptop?
Old Jul 7, 2008 | 04:08 PM
Protostar1's Avatar
bump on that question^^^
Old Jul 7, 2008 | 05:27 PM
RevMoto's Avatar
you can delete the code but it will probably come back. Just put an antifouler on it, much cheaper than a tactrix cable.
Old Jul 7, 2008 | 05:32 PM
4WS Tuning's Avatar
Yep! And with a tune I can turn that off for you.
I sell Tactrix cables for $90 shipped.
Cheers!
Old Jul 7, 2008 | 05:39 PM
RevMoto's Avatar
Cheers!
that is worth getting a cable
Old Jul 7, 2008 | 05:56 PM
Fast-Mover's Avatar
Just go buy the Helix SEL Fix for 13.99 off of gurppes.com, Simple and most O2 codes wont pop
nirvancol
Jan 6, 2017 12:24 PM
tbiggs
Lancer Troubleshooting
22
Jun 4, 2013 07:14 AM
ralliart610
Jan 10, 2010 09:22 AM
fox2boost
Northeast Region
13
Sep 10, 2008 08:56 PM
PunoEvo1337
Aug 17, 2005 06:26 PM
