O2 Sensor CEL fix
Old Aug 16, 2005 | 12:41 AM
PunoEvo1337's Avatar
O2 Sensor CEL fix
I was reading up on some of these ideas... anti-foulers and simulators
This was in the HowTo forums:
https://www.evolutionm.net/forums/sh...threadid=56631
In one of the posts someone talks about cutting the wires!?!
I thought that this was bad because the ECU needs some sort of electrical signal from the rear O2 sensor.
Will this work or am I just reading this wrong.
Any clarification on what they are doing with pulling the wires would be helpful also.
Old Aug 16, 2005 | 12:53 AM
Compjoc's Avatar
what kinda test pipe do u have?
Old Aug 16, 2005 | 12:58 AM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=114931
Old Aug 16, 2005 | 01:10 AM
Vishnu test pipe
Old Aug 16, 2005 | 01:14 AM
I am trying the anti-foulers tommorrow... i was just trying to keep my options open if these do not work
Old Aug 16, 2005 | 01:18 AM
Compjoc's Avatar
I use the anti-foulers, they work great.
Old Aug 16, 2005 | 01:21 AM
Itsmeeeugene's Avatar
www.gruppe-s.com sells the helix mechanical o2 fix. they work wonders. some people get problems with using anti-foulers, some dont. i just opted with the helix because it just doesnt caust any problems and its direct bolt on, so theres no crap u have to mess with.
Old Aug 16, 2005 | 01:24 AM
What kind of test pipe/cat-back are you running... i havent examined the o2 bung closely enough to see if i can get 2 anti-foulers in there, ill know after work tommorrow
Old Aug 16, 2005 | 01:26 AM
JoeA's Avatar
Tried the anti fouler trick but didnt work for me. I ended up with the gruppe-s fix. For some reason you can only buy it online. Its under the wrx parts and costs 15 dollars. Have had it on for a couple thousand miles and no problems.
Old Aug 16, 2005 | 01:28 AM
Compjoc's Avatar
I have a Works resonated test pipe. I used the O2 bung in my AMS cat-back for the anti-foulers/O2 sensor.
Old Aug 17, 2005 | 06:26 PM
alicea8541's Avatar
Anti-foulers for me and they work like a charm. I don't recommend cutting wires for nothing, SES light will definitely come on when it is dealing with emissions.
jkim2001
21
Mar 31, 2004 06:44 PM
evo_dan
Canadian Forum
Nov 13, 2003 08:34 PM
KK
EvoM Announcements
31
Oct 29, 2002 09:22 PM
