Autometer Wideband
Old Jun 21, 2008 | 05:21 PM
Jp7's Avatar
Jp7
Autometer Wideband
UPDATE: POST IN THIS OTHER THREAD INSTEAD
https://www.evolutionm.net/forums/sh...d.php?t=358243
I was going to buy this...
http://www.autometer.com/cat_gaugede...earch&gid=3603
It matches my other gauges (I have all sport comp gauges)
Anybody know if this is a good wideband?
Old Jun 22, 2008 | 06:46 PM
Jp7's Avatar
Jp7
burp! - anybody?
Old Jun 24, 2008 | 02:05 PM
speedy evo's Avatar
i use the aem, i know aem is the most popular one in the forum i really dont know much about that one.
Old Jun 24, 2008 | 02:32 PM
mplspilot's Avatar
Description looks good. You should find out if it's supported by major logging programs. Like Evoscan and Mitsulogger. Also if it has a simulated narrowband output.
Otherwise as just a WB, it should probably work just fine.
Old Jun 29, 2008 | 09:20 PM
Jp7's Avatar
Jp7
How can I find this out? I have to make my decision quickly because I am going on a trip the 4th.
Old Jun 30, 2008 | 05:25 AM
nianlala's Avatar
I would say a good place to start would be looking on the autometer website !
I hear google is a good search engine too !
http://www.autometer.com/productPDF/1143A.pdf
Old Jul 17, 2008 | 03:34 PM
Jp7's Avatar
Jp7
Have her installed now, for other members with widebands... I have a question.
How much is it normal for the AFR to vary in just normal (closed loop) daily driving?
Old Jul 17, 2008 | 03:40 PM
gsrboi80's Avatar
Stoich 14.7 man idle and cruise. It'll jump around a little though.
Get that analog output wire pinned into your ECU so that you can log it with your pulls
Old Jul 17, 2008 | 03:43 PM
Jp7's Avatar
Jp7
I can watch mine change as I drive. The question I had was what values do others see it jump too. Normally it is stoich at 14.7, yes I know
Old Jul 17, 2008 | 03:50 PM
gsrboi80's Avatar
mine will go as low as like 14.3 and as high as like 15.1 sometimes thats normal no worries
Old Jul 17, 2008 | 03:55 PM
Jp7's Avatar
Jp7
Mine goes from 14.0 to high 15.7 when I am at near constant speed.
When I accelerate somewhat gradually (not mashing the gas hard) , it may get as low as mid 12's
Old Jul 17, 2008 | 03:58 PM
gsrboi80's Avatar
Like I said man no worries. Stand on that **** from 3k in 3rd and then you'll see it a steady AFR. Plus you'll know if you tune has any room for inprovement
Old Jul 17, 2008 | 06:38 PM
Jp7's Avatar
Jp7
I tried that on the way home. I am getting a solid "10" and thats the lowest she goes. I think something is wrong, it's supposed to be 11.5 when it was tuned by chris at AMS
Old Jul 17, 2008 | 06:48 PM
andrewzaragoza's Avatar
if you have a tactrix cable and an evoscan or mitsulogger you could log some runs to see exactly what is going on. i remember seeing a thread here on how to log the aem wideband.
Old Jul 17, 2008 | 06:50 PM
Jp7's Avatar
Jp7
why would I need to log it if i can look with my eyeballs and see "10.0"?
I bought a wideband so that, for now atleast I could see if there was any problem in my AFR.
