TTP piston drop in project - amazing!
Old Jun 24, 2008 | 12:02 AM
  #46
RanEvo's Avatar
Originally Posted by riceball777
nice write up? did you file the pictons rings for the proper clearances? check piston to wall clearances and check rod bearing clearances???
Yes
  #47
RanEvo's Avatar
Yes
Old Jun 24, 2008 | 12:06 AM
  #48
RanEvo's Avatar
Yes, rod bearing are stock size
Old Jun 24, 2008 | 02:00 AM
  #49
RanEvo's Avatar
Originally Posted by vaflyboi757
i thought about doin this with 9.5:1 or 10:1 compression pistons, how much did the whole thing cost you? and how long was the car down for this?
If you have a good tune, I think 9.5:1 will be good.
For pricing contact Scoot from TTP, he will take car of you.
The complete job was only 3 days!! That is the advantage of this drop in piston thing, isn’t it??
Old Jun 24, 2008 | 03:14 AM
  #50
dsmfan95's Avatar
I would like to try a high c/r drop in build. Going to research some more first though.
Old Jun 24, 2008 | 06:29 AM
  #51
l2r99gst's Avatar
RanEvo, nice job.
Did you use a stretch gauge or just torque specs when putting in the rods?
Old Jun 24, 2008 | 06:36 AM
  #52
RanEvo's Avatar
Originally Posted by l2r99gst
RanEvo, nice job.
torque specs
Old Jun 24, 2008 | 06:52 AM
  #53
MrJdmJimi's Avatar
well how is it running ..
Old Jun 24, 2008 | 06:58 AM
  #54
justboosted02's Avatar
http://www.arp-bolts.com/Tech/TechInstall.html
Old Jun 24, 2008 | 11:36 AM
  #55
RanEvo's Avatar
the car running amazing
I will open new post as to that, as I have few more surprises, that I'm sure you guys will be happy to hear about
Old Jun 24, 2008 | 11:48 AM
  #56
1slowevo's Avatar
Congrats on the new setup. That piston/rod combo looks nice
I just did a very similar procedure and the car is running great!
Looking forward to the new numbers that bad boy will produce
Old Jun 24, 2008 | 11:56 AM
  #57
deadbeatrec's Avatar
this is almost exactly what i did. except the differences with mine are i used
wiseco pistons 9:1
eagle h-beams
and i did mine at 35,000 miles.
Old Jun 24, 2008 | 12:04 PM
  #58
Originally Posted by RanEvo
my apology for not getting back to you, I was slipping
anyway, I believe you understand now that I haven't removed the crack, so main bearings are not my concern. as for clearance issues, as the TTP JE pistons are custom to stock size, and my assumption (after compression and leak test before head removal) is that we have healthy engine to start with, the concerned will be only the honing issue, so that's why slight honing was carried to break the glazing only.
I will not argued as to my tuning, but this picture of the valves on the head will say more than I have to explain about the lambda in my tune before the drop in job
yours looks different than mine. all my valves are black as if it was rich, but my dome if u will is clean and yours is all black.
any experts here can explain to me whats the verdic for these heads?
Old Jun 24, 2008 | 02:59 PM
  #59
HeadGames's Avatar
Ran's head looks like it had a fuel additive...and some carbon. The second head looks like it has been cleaned prior to the pic being taken and you use straight gasoline.
Old Jun 24, 2008 | 03:02 PM
  #60
HeadGames's Avatar
even though I completely rejected the idea, and still do..for the same reasons Nick mentioned and my own..but, I admit it looks good Ran.
