Installed: Buschur Racing Mustache bar and Side supports
Old Jul 11, 2008 | 10:12 PM
  #31
EvoDan2004's Avatar
Originally Posted by antilag_200
^ that is good to hear, How does the driveshaft feel ?
I recently put the car back on the hoist, and installed the stock rubber busching/spacer, While I was under the car, I noticed that there is another aluminum mini subframe that attaches to the chasis. This piece is what the Main Billet parts from buschur attaches to. Maybe in the future this could possible be another area that can be eliminated or produced from a different material to reduce even more weight of the car.
Great Mod that is for sure.
im stupid and blind. but i put the car on the lift today to look at what your talking about. i dont see it. mind snapping a pic?? im always up for some more light weight parts. hehe.
Old Jul 12, 2008 | 04:29 AM
  #32
antilag_200's Avatar
please see image
it is number 6 on the drawing.
I don't really have a good picture of it but if you look under your car following the the image below
Old Jul 12, 2008 | 07:10 PM
  #33
EvoDan2004's Avatar
oooo i see now. now is this already aluminum or no??? if it was i would expect the price to be over 250 to be made and the weight would be probably nothing.. if it was cast iron then i bet another 12/15lbs savings. im interested.
Old Jul 12, 2008 | 07:14 PM
  #34
Blue Evo 8's Avatar
please see image
So according to Buschur, we're supposed to reuse part #7?
What if I already lost mine?? Can I substitute something else instead?? Maybe I can pick up some washers from Home Depot or something
Old Jul 12, 2008 | 07:18 PM
  #35
EvoDan2004's Avatar
yes #7.
i have ams rear bushings im thinking of useing instead of the rubber stock ones. if i do and i like the outcome ill give you my stock bushings.
Old Jul 12, 2008 | 07:22 PM
  #36
David Buschur's Avatar
Yes, #7 is what you re-use. IF the side diff support you got from us tightened up against part #6, then you do not need to install the washer.
Old Jul 12, 2008 | 07:26 PM
  #37
Blue Evo 8's Avatar
Originally Posted by evodan2004
yes #7.
thanks.......
Dave,
i'm still a bit confused though, part #6 is the entire beam....dont you mean part #8? #8 can be used as a substitute for part #7?
also on the aluminum side supports is it still ok to torque the bolts down to factory spec? It wont mess with the aluminum?
Old Jul 12, 2008 | 07:29 PM
  #38
EvoDan2004's Avatar
thanks.......
Dave,
part 8 is not used
  #39
EvoDan2004's Avatar
i was bad. i did not trq. i just gave it the yea thats good with the impact gun. haha
Old Jul 12, 2008 | 07:36 PM
  #40
Blue Evo 8's Avatar
thats good..... I cannot afford to break any bolts... as today I snapped a cam bolt while reinstalling my HKS 280's ....now I gotta look for a new bolt...
Old Jul 13, 2008 | 07:29 AM
  #41
From What I can tell Dan, the number 6 part, is made out of aluminum, so I doubt that it is very heavy, worth a shot though, i Suppose.
yes I was bad too, I just tightened everything up with the good ol snap-on impact gun
p.s dan, I don't think you want to use the aluminum bushings incojunction with the buschur side supports, because the pitch and yaw of the diff might be compremised. I noticed that the rubber bushing, squishes up, to take up any differences in elevation or pitch that the pumpkin might have ... Just a thought.
Old Jul 13, 2008 | 07:38 AM
  #42
EvoDan2004's Avatar
yea i thought about that as the diff has a angle to it and the bushing compressed more on one side then the other. i would have to shave an angle on the bushing and it might be more hassle then it is worth.
i think billet aluminum motor mounts would save about 5 to 8 lbs if you do the 2 sides and the rear. the stockers are pretty heavy.
Old May 31, 2018 | 07:11 AM
  #43
Bmurray's Avatar
Guys does dropping the subframe throw off the alignment you think? Since it’s connected to those rear LCAs.
Old May 31, 2018 | 08:13 AM
  #44
This is a popular topic on most car forums. The general consensus is, for sure, get a rear end alignment after removing / replacing the rear sub frame
You should share your findings to confirm
Old May 31, 2018 | 09:33 PM
  #45
Bmurray's Avatar
thank you. I assumed so. Also, did I overlook the torque specs for the side support bolts that go into the underside of car? I noticed it’s kind of squishing that upper bushing that’s supposed to be re used and want to make sure I don’t over tighten.
