New FP White turbo
Old Jul 7, 2008 | 04:12 PM
  #466
importjake00's Avatar
Originally Posted by TKEVO
OMG....*****This just in, Sorry to burst FP Whites bubble but the FP RED IS HEREhttp https://www.evolutionm.net/forums/sh...&postcount=187
lol.......... a little late buddy hahaha
Old Jul 7, 2008 | 04:26 PM
  #467
TKEVO's Avatar
Veteran: Air Force
I haven't been looking up anything else today but for sale ads mostly. Trying to pick up a green. It was posted today that it will finally be available.
Old Jul 7, 2008 | 04:27 PM
  #468
RLLN247's Avatar
Quote:
Originally Posted by Indy Evo
The White will be my choice for a daily driver. It does everything I need it to do and then some. The Green is up for sale. Indy
Originally posted by evorecordsetter
you must be one of those people that has to have new things for no other reason than just getting something new. the green spools so fast, that you will not even notice the white being any faster, and you will notice the loss of top end. seems like a silly thing to do. the green has retardedly good spool, and your going to get rid of it, for a 200(or however much faster it is) rpm, and lose 20 hp(of whatever the exact #'s are) WORTHLESS.
Well he just ordered a red too.Go figure.but hey He's bringing some great stuff to the evo community.
Old Jul 7, 2008 | 04:29 PM
  #469
Just f(ckin with you man.
I dont know if the reads gonna be a good DD or not yet..
Old Jul 7, 2008 | 04:31 PM
  #470
jroller's Avatar
Originally Posted by hokiruu
That's interesting conceptual thinking, and bona-fide "big turbo" guy talk, but on the flipside, there are only three E85 stations in my entire state. It's been this way for almost two years. Buying a daily driven turbo for a fuel supply that may never come is stupid. "Talk is cheap"? Did you miss several pages of technical data that Tom and other provided? Sorry but honestly the cheapest talk in here is yours.
This is your second time posting on this thread using "run with the big boys" rhetoric on why this turbo isn't for you. If you have established that for yourself, why bother, unless you are going to share some technical explanation on why you don't think this turbo is right for anyone else as well?
"there are only three E85 stations in my entire state." You may want to double check your facts before you speak. As a matter of fact there are SEVEN e-85 stations in your state with three of them resided in Santa Fe alone (with two more scheduled to be built by 2009). So my reasoning for a larger turbo stands: to take adavantage of higher octane fuels that are only becoming more prevalent and cheaper. Less $ more power. If your not into that, we haven nothing in common and hence forth have no reason to discuss performance cars.
Ever-Ready Oil Company
1200 1st St., N.W.
Albuquerque, NM 87102
505-242-5291
View Map
Sandia National Laboratory
Albuquerque, NM 87185
Sangre De Christo
247 C Montezuma Route
Las Vegas, NM 87701
505-426-7403
Los Alamos National Laboratory - 2
Los Alamos, NM 87545
View Map
Giant #6863
1229 Cerrillos Rd.
Santa Fe, NM 87501
505-954-4522
View Map
Giant #6864
4354 Cerrillos Rd.
Santa Fe, NM 87507
505-424-3076
View Map
Nambe Falls Travel Center
17730 U.S. 84/285
Santa Fe, NM 87506
505-455-5525
View Map
Old Jul 7, 2008 | 04:43 PM
  #471
Boltz.'s Avatar
FCOTM Winner
You're not in any position to give Indy advice. Do you know what he has done in the past few months since he's surfaced?
Old Jul 7, 2008 | 05:10 PM
  #472
GrocMax's Avatar
Get it now?
Originally Posted by 03whitegsr
Just when I was about to order up a white, you say the best is yet to come.
Oh well, guess I'll just run the IX for now and wait to see what comes out in the future. As fun as fast spooling high torque is, I think I still like the top end pull of a 70+ lb/min turbo better.
When is there going to be a thread about the 60lb/min mentioned by Robert???
Old Jul 7, 2008 | 05:14 PM
  #473
Indy Evo's Avatar
Scott nice job on both projects!
Old Jul 7, 2008 | 05:52 PM
  #474
evoPirate's Avatar
My IX turbo is in the mail tomorrow Now its just time to decide between White and Red....
Old Jul 7, 2008 | 05:58 PM
  #475
GrocMax's Avatar
Here's a little more graphing white vs 1580 with some flow data. If you think the 1580 is better by strictly looking at mass flow you would be very wrong. The 1580 is MAXED OUT, the white is not. Converted into volumetric flow the white is substantially higher at a lower PR and boost due toi the elevated inlet temps of the white. The cards are stacked in the 1580's favor via 25C cooler inlet temps, higher PR and boost pressure, but the white still kicks its *** in efficiency by a large margin. This is a maxed out 1580 vs a white cruising along. Note the exhaust pressures- THIS IS THE SAME TURBINE WHEEL AND EXACT SAME EXH HOUSING!!!
Here's the same strip chart but with data displayed in a different way, the vertical cursor in the strip chart above now shows up as two crosshairs. I see this by clicking the tab on the above screen called Mixture Map (scatter graph). This is NOT a true efficiency calculation (I2 will not accept the maths) but something we call Simple Efficiency, it works good to see how things are in transition and live. The 1580 has nosedived, the white has another few lb/min to go before it hits the wall.
Old Jul 8, 2008 | 01:42 AM
  #476
1NastyMR's Avatar
How much does this new Red flow? It put down 530 but at 38lbs... that much boost obviously would require a fully built car... i dont see the red making good power on stock motor cars/ lower boost levels say 28-30 psi ??
Old Jul 8, 2008 | 03:33 AM
  #477
Jorge T's Avatar
GrocMax, what caused the 25C inlet temps? was it hotter that day? or the turbo is making the IAT hotter?
Old Jul 8, 2008 | 04:12 AM
  #478
Steveevo9's Avatar
Good luck with the sale Indy, that green should move very quickly mate.
Exciting times ahead, are you going a cam with the new purchase? With your exact set up being a DD, that should have some mumbo in the midrange .
Please keep us updated with the new mani/White combo, lucky you.
Cheers Steve
Old Jul 8, 2008 | 04:27 AM
  #479
GrocMax's Avatar
That is COMPRESSOR inlet, not IAT. 56C vs 33C at point of cursor, and more delta than that earlier.
Hot day.
Old Jul 8, 2008 | 04:35 AM
  #480
GrocMax's Avatar
Wrong thread.
