any one using these?
Old Jun 28, 2008 | 08:56 AM
wartownracer's Avatar
Is anybody on here using aftermarket exhaust manifold studs? If so which ones are you guys using and how are they holding up with rusting or turning that ugly brown color? Im tired of the ugly looking rusty factory ones and want to try some stainless aftermarket ones but i have heard of aftermarket studs backing out and just would like to see if anybody can give me some first hand input. TIA
Old Jun 28, 2008 | 09:27 AM
bump
Old Jun 28, 2008 | 10:53 AM
nobody has or has heard anything about aftermarket mani studs?
Old Jun 28, 2008 | 11:22 AM
jmelocik's Avatar
I posted a link a while back on another thread about stainless manifold studs and the stainless hardware to hold the ARC manifold heat shield on. The problem with stainless is although it resists corrosion 100X better, it is actually a little weaker then the factory studs which are 10.9 grade steel. However if put in correctly they shouldn't back out. I am still rockin the factory studs with an after market manifold, no problems thus far. I'll see if I can find that link for you. Go to the link below and go back to the metric page and see if the studs that you are talking about are there.
Josh
http://www.boltdepot.com/product.asp...&cm=19&cd=1245
Old Jun 28, 2008 | 12:07 PM
thanks man...maybe i will just keep the factory studs and get some new oem nuts to clean up the look a little bit. Thanks for sharing the info.
Old Jun 28, 2008 | 12:12 PM
whoang40's Avatar
yeah stick with OEM. I put back my OEM exhaust manifold after the porting and haven't had any leaks. I'd only replace them if they got damaged.
Old Jun 28, 2008 | 12:46 PM
yeah i guess i should stick with "if it aint broke dont fix it" motto. Thanks guys.....if anybody else has any input please chime in.
mikgsxx
Oct 14, 2015 01:35 PM
EriCS
Oct 25, 2013 04:45 PM
AustinB768
15
Jul 18, 2012 07:44 AM
cody92talon
Dec 27, 2011 06:41 AM
wongck
Feb 17, 2009 08:35 AM
