My Twin Pump custom build
OK, thanks guys for the gazillions of cool info.. I got what you mean!
I have wired the pumps independently: 1st is on stock harness from ecu, not tampered with, and the second is wired directly thru relay to the battery. Adequate wires are used as noted by GTVEVO.
Now all i need is that pressure sensor to wire and adjust for the pump to run midway pressure between idle and max, since i do have a fuel regulator.
Scheides, I will post pictures of the under of the pumps to show exactly how it was done.. Very easy truly!
Wael
Wael
David Buschur
60
Aug 3, 2009 11:38 AM
fred 62
15
Nov 15, 2007 04:56 AM
Inn-Tune
42
Mar 11, 2006 01:32 PM
