Nitrous on stock head and block?
Old Jun 29, 2008 | 06:21 PM
Evoluvin's Avatar
Well ive searched on here trying to find threads on nitrous and everything, but could not find anything about it, I was just wondering a few things about it. Is it ok to run on stock block and head, what shot would i use.... etc etc , If anyone could fill me in on some good information about nitrous on the evo that would be great!
Anthony
Old Jun 29, 2008 | 06:26 PM
Jeff_Jeske's Avatar
Been there done that..... Its great for the occational need for more go.... but...
1. Its too easy to add a bigger jet. You may slap on a 50 shot and your car will love it. It may run perfect. Then you slap on a 75 shot and man oh man the car just rips and everything is in tune. Eventually you will build a false sense of security and try to add that 100 shot. This may actually work a few times but have one hickup with anything spark, fuel, knock, and WHAM!
2. The bottle is not instantly up to operating pressure. Even on 70 degree days a full bottle will need to be heated using a heater. That being said on 90 degree days the bottle may be over pressurized and you'll have to wait for it to cool down before spraying. When I say use the heater sometimes it takes 30-45 minutes to get a half full bottle up too 950PSI. In summary unless you open the bottle everytime you leave the house (and heat it) you wont be prepared for a drag race. You cannot just open the bottle on 1st ave and be ready to lay waste at 2nd ave.
3. Unless you own your own filling station and purchase a mother bottle from a gas/chem company you will probably get raped on the price you pay for nitrous. Around here I get charged $4.50/LB and a $5 hookup fee. I dropped the cash on purchased my own filling station. This dropped the price down to about $2.90/LB. Depending upon your location your prices may vary.
4. It's too easy to add a bigger shot
5. There is additional added fear that a part may fail and the motor may say goodbye. If your fuel solinoid takes a crap during a pass bad things could happen. Sure there are many safety items you can buy to prevent some issues but it is likely sooner or later something not soo good will happen. Bad things have happened to me. I actually melted a valve when I picked up a tank of bad gas. Apparently in some states they have enthanol "enhanced" fuel. This fuel was a poor choice to run with juice. I definately would recommend running race gas with laughing gas. I also had a nitrous backfire. I believe my bottle pressure wasn't quite where it needed to be (might have been cold) and when I went to spray I blew then entire intake side off the motor. The explosion was so massive it bent my throttle body blade. Motor was fine but I shat myself when it happend. I've also missed a shift and went WOT while on the juice since there was no load on the motor I didn't notice any fallout but if I had actually done a 1-2-3-2 shift and dumped the clutch there would have been pieces and parts everywhere.
6. It's too easy to add a bigger shot
7. You have to prep your car for juice. On a turbo car you WILL need to pull timing and if you are running bleeding edge boost you'll have to back it down because nitrous will cause it to creep. Prepping your car also means running the correct spark plugs and odds are your clutch will not appreciate it at all. If you are serious about keeping your motor healthy you'll have to check your plugs after each session of spraying. Reading plus is about the best way to determine how the motor is responding. In the end its very cheap power IF you run a big shot, but with all the cons that come with it it may just be BETTER to upgrade something else, get a little less power, but have it all the time.
Some more info..... if you are using stock launch control you aren't going to use juice from the dig. You'll probably flip the switch after getting into second gear. If you aren't using LC you can use self control to not nail the pedal all the way down until you have traction and full clutch engagement. It helps to add an MSD RPM window switch to save you from too early of engagement or from an accidental miss shift.
With race fuel you will not need to retard timing. On 100 you should be able to run 23psi and a 75 shot on your 93 octane pump gas map. I wouldn't recommend a dry system that would require increasing fuel pressure and its just a PITA to work with on a boosted car. If you are serious about nitrous a direct port system is the hot ticket but most people stick with the single fogger wet system. I prefer Nitrous Express but NOS is very good too. You'll find jetting charts that are a little different between vendors but NX rates their gains at the wheels. A 31 is a 35WHP shot. A 35 is a 50WHP shot. A 42 is a 75WHP shot. I ran a 46N/26F which was good for an additional 100FT/LBS of torque and 87WHP. The numbers will be different for each platform as they are rated gains on a stock car. If you have cams and your buddy doesn't you will see different gains.
My advice is get all the bolt on mods first then if you feel you still need a secret weapon, toss on the sauce. Its expensive. I got about 10 full 1/4 mile runs out of a 10LB bottle with the 46N jet. Putting into terms that make sense..... each race cost me $5 in nitrous. Each full pass cost the same as eating at Burger King. You have to have self control to use it only during a time of need or you'll see the associated cost add up very quickly.
Old Jun 29, 2008 | 06:34 PM
Odenl0ki's Avatar
Great info. Thanks.
Old Jun 29, 2008 | 06:51 PM
EVOLex's Avatar
Jeff speaks the truth. I'm a firm believer that nitrous should be added when there is really nothing else to add to a setup. To often, people think that adding a 50 shot is basically installing the system and going out and racing. I'd looking into other means of adding power.
Old Jun 30, 2008 | 12:21 PM
Evoluvin's Avatar
ok thanks guys for the helpfull info!!!!!
Old Jun 30, 2008 | 01:07 PM
joey a's Avatar
http://www.ls1tech.com/forums/forumdisplay.php?f=10
Go here if you want to find out real info and not talk to SISSY'S!
We were spraying a 125 shot on a stock bottom end 18G 2G with 272s, car moved out very well...But we did it on race gas, I wouldnt mess with pump...
Old Jun 30, 2008 | 01:13 PM
colo_evo's Avatar
Good point!
Nitrous in the right hands is very powerful, but in the wrong hands can be very dangerous.
Just like a large turbo... In the hands of an experienced tuner its great, but results may be vastly different in the hands of an inexperienced tuner.
Old Jun 30, 2008 | 01:31 PM
EVOLex's Avatar
What I was getting at is that there is some tuning that goes with a nitrous setup.
Old Jul 8, 2008 | 07:44 PM
Evoluvin's Avatar
ok thanks guys!!!
snakebite
20
Nov 5, 2016 06:26 PM
EpicEVO
22
May 15, 2008 08:17 PM
Demon_ni2
Lancer Aftermarket Forced Induction Tech
Nov 20, 2007 11:52 AM
s10v8
36
Dec 6, 2005 11:15 PM
EVOlunchbox
10
Feb 13, 2004 05:39 AM
