Noob Question
Old Jul 8, 2008 | 07:33 PM
iy's Avatar
iy
Noob Question
So my current Evo runs like a top, except for one issue which I will detail later.
Anyway, I was glancing around my engine bay and saw this
This doesn't look quite right. Does anyone know where this is supposed to go?
Also, the issue I have is that after prolonged deceleration (engine running on hard vacuum) my brake pedal gets very hard and the brakes drag. Driving hard and boosting actually seems to clear this up. I was thinking that it is the brake booster or (possibly) master cylinder but this certainly seems suspect.
Old Jul 8, 2008 | 07:35 PM
Ivan@AMS's Avatar
That goes to your intake tube. It looks like you still have the factory one. Look for a large plastic nipple that it attaches to.
Old Jul 8, 2008 | 07:37 PM
iy's Avatar
iy
Problem is I have the Injen intake (the PO put it in). Nipple should be on intake?
Old Jul 8, 2008 | 07:40 PM
gmore84's Avatar
it doesn't need to be attached. it's like a breather. it will be fine. people usually but small like filters where that goes. i would keep it on. it helps if excessive oil builds up on ur head, therefore it will dump it to the ground. i have the same thing. care runs fine.
o-townFLA's Avatar
intake as in turbo inlet-to-filter...
Old Jul 8, 2008 | 07:41 PM
Ivan@AMS's Avatar
Yes.. should be on the intake tube. Large nipple on the left side of the intake in the picture.
Old Jul 8, 2008 | 07:43 PM
ak47po's Avatar
The Injen should have a nipple like 13 stock intake 12 is your hose.
Old Jul 8, 2008 | 07:47 PM
Ivan@AMS's Avatar
If no filter is attached, it allows dirt into the motor. Anytime the motor is in a vacuum condition, air is being drawn in through that tube. Any dirt in the air makes it directly into the top of your motor and into your oil.
Old Jul 8, 2008 | 07:56 PM
iy's Avatar
iy
Ivan, great call! I have that nipple masterfully plugged.
Any idea at all if this is related to my brake booster issue?
Old Jul 8, 2008 | 07:58 PM
SOEuro's Avatar
vent that line to the bottom of your car...i wouldnt suggest putting it back into the intake,because your intercooler will get filled with oil
btmboards
Mar 5, 2012 08:32 PM
MileHighX
May 21, 2011 07:07 AM
blaze_125
May 22, 2009 09:50 AM
zorca
Mitsubishi TC-SST Discussion
Jan 8, 2009 02:09 PM
Rcebowl
18
Aug 5, 2006 11:33 AM
