Help Please!!
Old Jun 30, 2008 | 06:24 AM
TEAM ACE's Avatar
Help Please!!
Ok so i did a launch yesterday, and after the launch my clutch does not work any more.
the clutch pedal feels the same i didnt here anything break. i thought my lingage or tranny locked in place but i shut the car off and put it right in gear. so to get it home i started it in gear and drove home in first.
my first thought would be clutch fork but the pedal feels the same. second thought would be pressure plate but then the car should not move.
does anyone want to point me in a direction?
Old Jun 30, 2008 | 08:42 AM
EVOLex's Avatar
My first guess is the Clutch release fork, but if the pedal still have pressure, you can almost certainly rule that out. why not climb under the car and check the Slave cylinder and maybe even unbolt the it, and try wiggling the clutch release fork to make sure it is still in one piece.
Old Jun 30, 2008 | 09:57 AM
TEAM ACE's Avatar
the slave cylinder is still working fine... should i unbolt it and look through that bolt or should i go through the inspection hole at the bottom. or just pull the damn tranny again?
Old Jun 30, 2008 | 09:58 AM
TEAM ACE's Avatar
slave cylinder boot not bolt sorry typo
Old Jun 30, 2008 | 11:03 AM
EVOLex's Avatar
Just unbolt the slave cylinder and wiggle the fork that protrudes from the transmission (ie the piece that the slave cylinder pushes).
Old Jul 1, 2008 | 07:07 AM
TEAM ACE's Avatar
so i took the boot off slave cylinder off and bottom inspection hole. i dont see any broken pieces the slave cylinder works fine and the clutch fork doesnt seem to be broken. i guess my next step is to yank the tranny out again.
did anyone else ever have this happen so i at least have an idea?
like i said there are no odd noises .
thanks
cbarno042
Sep 1, 2016 05:47 AM
thadon84
38
Aug 23, 2016 12:35 PM
Darksun280
Apr 20, 2013 01:19 PM
jonzie04
May 22, 2012 12:41 AM
Tek3Evo
Aug 14, 2008 01:25 PM
