Car shakes at idle with AC on.
Old Jun 30, 2008 | 03:14 PM
rcheung's Avatar
I know i've seen a few threads on this topic before but the search cuts off any words less than three letters. Starting a couple of days ago my car would shake violently at idle whenever the ac is on. It doesn't do it when I only turn on the fan so it might be compressor related. When I'm driving and turn on the AC its fine until I shift gears. When I shift gears with the ac on I have to be fast because If I leave the clutch down too long the rpms go down to almost zero and wants to stall. Some people stated they experienced this with the front engine mount but I've had it for over six months and it only started 2 days ago. This also isn't a little vibration it is a violent shake where you can definately notice the change in engine behavior if your outside the car. The AC cools just fine. Any advice on how to start to diagnose this issue?
Old Jun 30, 2008 | 03:18 PM
meckert's Avatar
The idle should pick up when the ac goes on...my guess is that the automatic switch that controls that isn't working--so ac comes on, loads the engine, drops the idle and theres your problem..
Old Jun 30, 2008 | 03:21 PM
GinNBoost's Avatar
After I installed my Blox front engine roll stopper, my car also shakes badly at idle when I have the AC on. I think that's normal though...
Old Jun 30, 2008 | 03:23 PM
rcheung's Avatar
I would too except it didn't happen until a few months after I installed it
Old Jun 30, 2008 | 03:25 PM
rcheung's Avatar
Is there a way I can check it on my own to see if thats the issue?
Old Jun 30, 2008 | 03:31 PM
holler mcdollar's Avatar
normal.
Old Jun 30, 2008 | 03:55 PM
srcevo8's Avatar
I say normal too. You have cams...what do you idle at? I raised my idle to 900-1000. If I turn on my A/C at idle things drop to like 700 and gets rough. I don't think you necessarily have a problem unless something is wrong with the compressor...like something is loose. But I dunno. This sounds like my car lol.
And when I had a 350Z and turned on the A/C at idle the same thing would happen. So to me this doesn't sound serious unless your idle is already set high (>1k).
Old Jun 30, 2008 | 04:04 PM
Curt@MrLed's Avatar
Former Vendor
Cams, A/C, Idle=fail.
Old Jun 30, 2008 | 04:12 PM
gsrboi80's Avatar
Too ture farmer LOL
Im guessing the OP just started using the AC for the year. If you havent used the AC since the last time you disconnected the battery. These EVOS really take some time to relearn (If you will) idle. Its seprate idle settings for AC on and off too. So it'll have to relearn regular idle and AC on idle. I expierience this in my car quite often it'll get better
Old Jun 30, 2008 | 06:04 PM
Sluggo's Avatar
Exact same with me. Good thing I hate using the ac with a passion.
Old Jun 30, 2008 | 06:45 PM
GinNBoost's Avatar
Yeah I hate using the A/C too haha. I'll only resort to using it if I'm taking a long highway drive and it's like 100 degrees outside.
Old Jun 30, 2008 | 07:52 PM
Odenl0ki's Avatar
Just dont use the AC at idle if you can avoid it. I think it has to do with your cams as some of the others have stated.
Old Jun 30, 2008 | 09:32 PM
evotuner04's Avatar
15 Year MemberLikedLoved
ive got the same issue its not a terrible idle but you can tell it drops and then goes back up after a couple seconds and i dont have cams....so i wouldnt worry
Old Jun 30, 2008 | 09:36 PM
evotuner04's Avatar
wait i actually read your whole post about it....umm well if its a violent shaking then its prolly not good lol and it prolly is something not working well if your having that kind of problem...take a closer look at it and try and give us some more info
Old Jun 30, 2008 | 09:41 PM
bluebanana23's Avatar
I have the exact same problem so I only use it for long highway trips due to the lack of shifting.
