Hissing sound at idle near firewall
Old Jul 1, 2008 | 07:12 PM
berkel's Avatar
Hi,
Haven't posted much for quite awhile, but I've been driving my Evo VIII for 88K miles or so. I was on stock clutch till ~75K or so too.
Anyway, lately I've noticed sluggishness between 3-4 K rpm, and suspected a boost leak. I popped the hood at idle and I can hear fairly loud hissing which seems to be coming from near the firewall in the center of the engine. I kind of thought it was emanating from the hose on my PVC side DIY catch can, but would that hiss at idle and leak boost? I wouldn't think so since some peeps just bought a filter on there...
Maybe it's coming from the TB?
Strangely, I'm getting pretty good gas mileage, which I wouldn't expect. I can finally get more than 250 miles out of a tank, lol.
Then again, maybe it always made that noise and the perf is just due to the heat? Any thoughts?
<edit>
Now, I'm thinking it's the FPR line where I teed for the boost gauge. If that were torn, could someone please enlighten me on the "symptoms"? Now that I think about it, my Walbro has been whining louder lately, does that all tie together? TIA!
</edit>
Thanks,
FB
Old Jul 1, 2008 | 08:18 PM
apex IX's Avatar
you might wanna look 4 a vaccum leak, you would hear that at idle and thats a hissing sound and would make your car run slugish
Old Jul 1, 2008 | 08:54 PM
ccboy37373's Avatar
I have the Ported Buschur TB and it kinda hisses but I doubt the factory TB would.
Old Jul 2, 2008 | 07:04 PM
berkel's Avatar
Thanks guys, I tightened down the tee connections where my boost gauge hooks in. The one that I think got it was the vacuum line from the next to the FPR where it hooks into the intake manifold. I replaced it and hissing was greatly reduced and car spools much better. Wow, I like this car again!
I should go through and replace as many vacuum lines as possible, car is ~5 years old!
Take care,
FB
Old Jul 2, 2008 | 11:03 PM
MRfabolous's Avatar
you might want to check some of the vacume lines behind the intake manifold on the bottom they tend to come off i had one for about a month and did not even know it zip tie those bad boys.
Old Jul 2, 2008 | 11:07 PM
Erik@MIL.SPEC's Avatar
Could also be your throttle shaft seals.
Ted B
148
Jun 5, 2025 01:24 PM
thedru13
Mar 31, 2016 09:08 PM
cazlow
11
Apr 10, 2012 11:21 AM
Stage2evo8
Aug 14, 2011 09:46 AM
sir monster
17
Mar 27, 2010 11:18 AM
