supercharger whine
Old Aug 13, 2011 | 10:42 AM
Stage2evo8's Avatar
supercharger whine
I just installed a tial bov and a new boost controller all of a sudden. Under fool boost instead of the high pitched hiss it sounds like a supercharger whine now? The tial isn't leaking and neither is the piping....any thoughts?
Old Aug 13, 2011 | 10:46 AM
ak47po's Avatar
Compressor surge.
Old Aug 13, 2011 | 10:47 AM
Evo Izzy's Avatar
Well I would check for boost leaks first off... I had this happen to my srt-4, turns out the compressor wheel was pretty busted up. Take a small mirror and check the fins on the wheel. Hope this helps...
-Izzy
Old Aug 13, 2011 | 10:58 AM
Stage2evo8's Avatar
Well it happened after i installed the controller the fins are fine as I'm running open turbo and can see them .. its weird ill post a video when i get a chance
Old Aug 13, 2011 | 10:59 AM
Stage2evo8's Avatar
And compression surge? While full spooling?
Old Aug 13, 2011 | 11:08 AM
Toole's Avatar
why would you run the turbo with no filter?
Old Aug 13, 2011 | 11:23 AM
Evo Izzy's Avatar
Open turbo? Well, if you are 100% the blades arent damaged, I would return everything back to stock. Start back at square 1.
-Izzy
Old Aug 13, 2011 | 11:32 AM
Stage2evo8's Avatar
LOL got the car like this can't go back to stock its a fully built 6262 with no filter I ordered one
Old Aug 13, 2011 | 11:33 AM
Stage2evo8's Avatar
And yes just checked blades are good .. I barely drive the car so if I had the choice I would have a filter on already I finally ordered one
Old Aug 13, 2011 | 10:19 PM
blackenedwings's Avatar
Hmm, I would double check the BOV... some combination of parts made my BBK Full and old Synapse BOV sound like a supercharger exactly. Very prominent and loud whine during spool. I assumed at the time it was simply the billet compressor wheel. However, I noticed recently when I replaced my BOV due to an unrelated issue with a newer Synapse BOV that the high pitched whine has gone and now I have a more traditional HUGE inrush of air sound. I also seem to hold boost more steadily... my guess is that my older BOV had a leak causing the audible sound.
Old Aug 13, 2011 | 10:37 PM
EvoJoeIX's Avatar
you obviously have a boost leak somewhere if its only making this noise under "fool" boost
Old Aug 13, 2011 | 10:39 PM
sr20detisbetter's Avatar
+1 for boost leak idea
Old Aug 14, 2011 | 09:46 AM
Stage2evo8's Avatar
Ok so I checked the blades and one is pretty tweaked.. has a piece missing :l ugh gotta get it rebuilt I guess
CAINuKe
May 22, 2017 06:02 AM
Outie11
Outlander Sport
19
Sep 30, 2015 03:27 AM
si00dcracer
10
Sep 29, 2015 06:10 PM
EVO4-6
20
Nov 7, 2011 10:39 PM
Raptor
Australian Forum
43
Nov 15, 2004 12:12 AM
