180 psi is this too high
Old Jul 3, 2008 | 07:27 AM
4drboost's Avatar
Just did a compression check after replacing my spark plugs........... all 4 cylinder came out to 180 psi. I was wondering isn't this too high for a Evo 9?
Old Jul 3, 2008 | 07:58 AM
TeStUdO's Avatar
What were your other 3? As long as they are all close, you are good.
Old Jul 3, 2008 | 07:59 AM
tvor's Avatar
I had 185's across the board in my stock engine.
Old Jul 3, 2008 | 08:10 AM
4drboost's Avatar
They were all 180 psi
Yeah but you have a Evo 8.....which I thought had higher compression but I could be wrong.
Old Jul 3, 2008 | 08:27 AM
tony gibson's Avatar
As far as I know, they have the same compression.
Old Jul 3, 2008 | 08:29 AM
TeStUdO's Avatar
VIII and IX=Same compression.
180 across the board=Healthy engine
Old Jul 3, 2008 | 08:34 AM
gsrboi80's Avatar
180=Real healthy engine
Old Jul 3, 2008 | 08:36 AM
cfdfireman1's Avatar
gauge may not be 100%
Old Jul 3, 2008 | 08:38 AM
justboosted02's Avatar
exactly
as long as the numbers are within 10%, you're good
Old Jul 3, 2008 | 01:19 PM
sk8terdude929's Avatar
They are good numbers
Old Jul 3, 2008 | 02:42 PM
RazorLab's Avatar
Incorrect, look at a service manual for both sometime.
Evo 9 is 145psi standard, 92 lower limit with no more than 14 psi difference between cylinders
Evo 8 is 163psi standard, 138 lower limit with no more than 14 psi difference between cylinders
OP: Was this compression test done on a cold or warm motor?
Old Jul 3, 2008 | 02:58 PM
4drboost's Avatar
The engine was hot and has about 23k miles on her.
Old Jul 3, 2008 | 03:01 PM
bank277's Avatar
I'm around 170 on all 4.
AKB_EVO
Dec 12, 2016 08:02 PM
McSlides
For Sale - Wheels / Tires
Mar 13, 2014 01:52 PM
TempeRacerGuy
185
Apr 5, 2010 11:00 AM
LOTL
For Sale - Cars For Sale
Jan 31, 2007 10:05 PM
Raptor
Australian Forum
16
Jun 22, 2004 11:40 PM
